Talk to Gavin at Custom Code. He comes down this way on a semi-regular basis.
mixed reviews and long dated posts unless i go through peoples posts hasnt gave the question im now asking verified.
who in SA can chip/tune my
99' mk4 1.8t ???
at a cost efficient price to date?
-graham west seems to pop up-this?
looking at moderate boost
cars on 125000 and will be getting this done after the usual new S.H buying problems get adressed.
thanks for any help,
Dan
DEEP POCKETS NEEDED
Transporter may be able to help you, but you may be in solder in chip territory. Do you have drive by wire or a throttle cable?
All Australian deleivered MK4s are cable throttle. Only the face lift A3s got a DBW system.
I can do MK4 GTIs without soldering chips. I do come to Adelaide but it's going to be September before I come again.
I have bench leads to do these, so if you just want stage 1 you can post the ECU to me. I have a loan ECU to keep you running if you need your car daily.
Turn around is 3 days. You post Monday, I receive, flash and post tuesday, back in the car wednesday.
$749
Gee that's hard to beat!
Did you buy lukes GTI?
Hey Guys,
I have a K03s (K03-052) turbo to replace the K03 on my AGU engine MK4 GTI. The car already has an APR Stage 1 Tune but the turbo has damaged compressor blades so it whines and doesn't produce much boost. Other than that the car has full 3" exhaust, cold air intake, silicon TIP and upgraded DV.
I want to sell the car ASAP but dont wanna get low balled by someone calling out the turbo whine so I purchased the K03s thinking it was a bolt on for the K03 and maybe it would even get more power
But now i'm reading that it would need a remap otherwise it may not run right or run too lean at the top end
Is this correct? If so can anyone do a K03s tune in Adelaide and what would the cost be
Im probably better off ebaying my K03s and buying a K03!
Cheers, Mike
I am not aware of anyone in Adelaide doing a K03s tune for the MK4 and a problem you'll most likely have is that APR will have soldered in an encryption board making you ecu essentially untunable. To confirm this though, you should take the ECU out and take the cover off. Post a picture and I'll confirm.
The K03s will be pretty twitchy on the k03 tune.
$849 for the K03s tune of you can go that route. I can do this on the bench if you post the ecu to QLD.
