Results 1 to 10 of 12
Thread: performance chip and tuning in adelaide
    Aug 2016
    mixed reviews and long dated posts unless i go through peoples posts hasnt gave the question im now asking verified.
    who in SA can chip/tune my
    99' mk4 1.8t ???
    at a cost efficient price to date?
    -graham west seems to pop up-this?
    looking at moderate boost
    cars on 125000 and will be getting this done after the usual new S.H buying problems get adressed.
    thanks for any help,
    Dan
    DEEP POCKETS NEEDED
    Talk to Gavin at Custom Code. He comes down this way on a semi-regular basis.
    Jan 2008
    Sunshine Coast
    Transporter may be able to help you, but you may be in solder in chip territory. Do you have drive by wire or a throttle cable?
    Quote Originally Posted by Greg Roles View Post
    All Australian deleivered MK4s are cable throttle. Only the face lift A3s got a DBW system.
    I can do MK4 GTIs without soldering chips. I do come to Adelaide but it's going to be September before I come again.
    I have bench leads to do these, so if you just want stage 1 you can post the ECU to me. I have a loan ECU to keep you running if you need your car daily.
    Turn around is 3 days. You post Monday, I receive, flash and post tuesday, back in the car wednesday.
    $749
    Jan 2008
    Sunshine Coast
    Gee that's hard to beat!
    Aug 2016
    Cool
    $749
    ok now we're crankin info..thought id get a search is your friend kent loosing it..
    gavin i will pm you im a noob to vw but not to modifying many other cars so some questions need to
    be asked..fast track me bruv.
    DEEP POCKETS NEEDED
    Munno Para West Adelaide
    Did you buy lukes GTI?
    Adelaide hills, SA
    Quote Originally Posted by DAM GTi View Post
    99' mk4 1.8t ???
    Dan
    All my tunes for older (incl. diesel) VAG cars are $650, no removing ECU required.
    Jan 2017
    Hey Guys,
    I have a K03s (K03-052) turbo to replace the K03 on my AGU engine MK4 GTI. The car already has an APR Stage 1 Tune but the turbo has damaged compressor blades so it whines and doesn't produce much boost. Other than that the car has full 3" exhaust, cold air intake, silicon TIP and upgraded DV.
    I want to sell the car ASAP but dont wanna get low balled by someone calling out the turbo whine so I purchased the K03s thinking it was a bolt on for the K03 and maybe it would even get more power
    But now i'm reading that it would need a remap otherwise it may not run right or run too lean at the top end
    Is this correct? If so can anyone do a K03s tune in Adelaide and what would the cost be
    Im probably better off ebaying my K03s and buying a K03!
    Cheers, Mike
    Quote Originally Posted by MB123 View Post
    Hey Guys,
    Cheers, Mike
    I am not aware of anyone in Adelaide doing a K03s tune for the MK4 and a problem you'll most likely have is that APR will have soldered in an encryption board making you ecu essentially untunable. To confirm this though, you should take the ECU out and take the cover off. Post a picture and I'll confirm.
    The K03s will be pretty twitchy on the k03 tune.
    $849 for the K03s tune of you can go that route. I can do this on the bench if you post the ecu to QLD.
