Why not just run the same tyre and adapter size sam had setup? Was perfect.
so the ****ers that are sending me my adapters are taking me forever, they were being custom made and sent so i don't know whats taking them so long !!
but in the meantime i gave the azevs some attention
so here what i got up to
wanted to give them a good clean !! as they were a bit dusty
DSC_5863
DSC_5864
I love the attention to detail even have g the logo stamped into the wheel with the diamond
DSC_5865
DSC_5867
DSC_5866
215x40's i think il go to 205x40
DSC_5869
DSC_5884
DSC_5878
i changed the valve caps as well, will be getting stainless steel valves as well when i change the tires over
DSC_5875
DSC_5877
the barrels were really clean !!
DSC_5885
DSC_5889
DSC_5893
all cleaned up, Coated the barrels with brake dust repellent and buying some new ceramic brake pads as well
DSC_5905
DSC_5906
and last but not least my ugly head
DSC_5915
aight will update this again when the adapters get here !!!
so finally got a message back from the guys in Melbs about my adapters
lets hope they're here by friday
so put the other guard back on and need to roll the guards some more
so i also took the sway bar links out and need to cut it out as well or drop my subframe and take it out
Really wanna go a bit lower, tbh i think it'll sit a bit lower as well as the car isn't on a flat surface atm
Thanks to a mate Chester ( some of you might know him, bagged r32 (DCUPS) ) - WCI MT10's i grabbed this plate holder coz my old stance works one got stolen
these plastic headlight lenses i got are holding up well!! Still on the search for some OEM glass ones
think its time for a Notch, will do it sometime in the next few months - self notched right now
i love these tails !!! so can confirm atm that they're the only Hella Clears in Australia - Dylan Taylor ordered some while back he said but got lost in transit - so if anyone knows of anyone who has them in Aus as well let me know !!
ok and also my side skirts arrived and i was upset in the condition they arrived in
Aus post or USPS handled it really bad and was ripped open and the bubble wrap was removed and only left on the tops
then the side skirts were snapped - so i have put a claim through and told the seller and he is taking care of it but for WTAC in october il just repair them
as you can see the cracks in the skirts line up with the box marks
but tbh they look alright will colour code it with the boar's paint same goes for the front and rear valance
they look good give the side of the car a bit more shape
til next time !!
What side skirts and front and rear are they if you dont mind me asking?
Side skirts are Bora R Reps from Optikwerks Volkswagen Body Kit
and front and rear lips are just standard 4motion ones man
oh nice, Thanks bro! Build is looking sweeet!
adapters have arrived !!! finally !! will put the wheels on tomorrow arvo
This is rad. It scares the **** out of me how low it is but I love it!
I can't believe the burn mark on the inside of the well. Thats nuts.
I went a little bit low on coilovers, but swapped them out for static Bilsteins. I just needed a more practical ride.
Wheels on yet?
How are you getting on with the Ground Control top mounts? I've just picked up a set of second hand ones.
Are you going to run engine mount raisers? A mate in the uk uses them, once you chassis is notched you get a bit more clearance on for the sump but also ensures your drive shafts are running at a safer angle.
