Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Passenger window fell into door
SasaG93 Passenger window fell into... 09-06-2013, 03:21 PM
Guest001 Take doorskin off find out... 09-06-2013, 03:50 PM
SasaG93 ive taken the door trim off,... 09-06-2013, 04:07 PM
Stan the doorskin is the outside... 09-06-2013, 04:12 PM
RolfGolf Once you've removed the door... 09-06-2013, 04:44 PM
Guest001 [QUOTE=Stan;960670]the... 09-06-2013, 05:15 PM
The One Hey mate this is very common.... 09-06-2013, 04:57 PM
jeremyex_ Sorry for bringing up an old... 04-02-2014, 08:14 PM
JustCruisn You may find you need the kit... 05-02-2014, 07:57 PM
jeremyex_ Passenger window fell into... 07-02-2014, 10:37 AM
dylan8 nar other way around. UK... 08-02-2014, 09:36 PM
aaron001au my passenger window dropped... 07-02-2014, 09:50 PM
blackers10 Try powerwin.com.au they are... 08-02-2014, 10:30 AM
jeremyex_ Sweet. Not as expensive as I... 08-02-2014, 02:23 PM
jeremyex_ Sweet makes it clearer. Cheers 09-02-2014, 11:43 AM
jeremyex_ So finally got around to... 20-02-2014, 06:11 PM
SasaG93 hey mate, im not too sure if... 21-02-2014, 08:56 PM
jeremyex_ Ah k thanks. Might as well... 22-02-2014, 05:28 AM
JustCruisn You want the metal ones. The... 21-02-2014, 08:21 AM
jeremyex_ Cheers mate. Wasn't sure... 21-02-2014, 11:25 AM
aaron001au im pretty sure i got a few... 22-02-2014, 10:19 PM
jeremyex_ Check pm's. 23-02-2014, 04:45 AM
    Nov 2012
    Wollongong, NSW
    So my friend had his arm Leaning out the window and when I went to close the window it hit his arm. When I went to close the window again it moved a little but then stopped. As we tried to close the window it somehow popped out and now is in my door. Anyone know how to fix this?
    2003 MK4 Golf 2.Slow (a.k.a the money hole) - 18' Lenso Type M wheels so far
    Pacific Paradise QLD
    Quote Originally Posted by SasaG93 View Post
    Take doorskin off find out which bit broke and fix it.
    Possibly the glass has come out of track
    Mamba Ebike to replace Tiguan
    Nov 2012
    Wollongong, NSW
    ive taken the door trim off, but im not sure about the doorskin???
    Jul 2009
    Geelong, Victoria
    the doorskin is the outside metal cover to the door - I'd be leaving that in place.
    with the inside trim off have a look and see what you can find - window may simply have jumped out of the track as suggested. There are plenty of cables and bits in there, so something there may have come undone. Also check the mechanism that holds the window channel, these can fail as well.
    If all else fails, take some pics and post them here
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Nov 2006
    Largs Bay, S.A.
    Once you've removed the door cards, you'll see the doorskin which you may need to remove - this video gives you an idea of what you're dealing with window track wise.
    Volkswagen Golf Jetta MK4 Bora Window regulator reparation - YouTube
    Cheers.
    [QUOTE=Stan;960670]the doorskin is the outside metal cover to the door - I'd be leaving that in place.
    If all else fails, take some pics and post them here[/QUOTE
    Both mine have inner skins as well, accessible from the inside and held on with Pop rivets
    Jul 2007
    Brissy
    Should be a lot of 10mm bolts holding the metal plate inside the door.
    The problem will be the window regulator, and its plastic parts.
    There is a great DIY here VWVortex.com - DIY - Replacing the front door window regulator clips and/or door lock module
    Get the kit from VW, about $120, then spend the better part of 3hrs fixing it.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jan 2013
    Brisbane, QLD.
    Hey mate this is very common. Go to your local dealer and ask them for. Window repair kit, it has everything you need in there and is not very expensive. The mk4 window tracks were always a problem but fixed with this repair kit....
    Feb 2013
    Sorry for bringing up an old thread.. But would anyone have a link to the repair kit on eBay? Not sure what to search for. This just happened to me lol
    Jul 2007
    Brissy
    You may find you need the kit not just the clip as the control wire will probably have made a complete mess inside the rollers etc.
    Search for "mk4 golf window regulator"
    Remember that Drivers side is LEFT pretty much everywhere except AUS and UK.
    VW MK4 GOLF BORA 4/5 DOOR WINDOW REGULATOR REPAIR KIT FRONT RIGHT METAL CLIPS | eBay
    MK4 GTI - Sold
