Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Passenger window fell into door
  1. #21
    Quote Originally Posted by jeremyex_ View Post
    Cheers! So I should be looking for a drivers side (left) repair kit if I were to buy from the UK or is the link above the correct one? Sorry just a bit confused
    nar other way around.
    UK should be the same as us. (drive left side of the road, drivers side of the car is the right)
    US, drivers side is the left of the car
  2. #22
    Feb 2013
    Sweet makes it clearer. Cheers
  3. #23
    Feb 2013
    So finally got around to taking off the door skin to find one of the clips broken. So.. Does anyone know if the metal ones on eBay will work? As the clips currently on my car look different (plastic).
    Metal clips:
    Plastic clips (current):
  4. #24
    Jul 2007
    Brissy
    You want the metal ones.
    The issue is the plastic ones perish over time and break. Same with the plastic water pumps. The solution is to get metal.
    Dealers wont stock the plastic as they have been superceded.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
  5. #25
    Feb 2013
    Cheers mate. Wasn't sure because they looked different
  6. #26
    Nov 2012
    Wollongong, NSW
    hey mate, im not too sure if the original cables from the plastic clips will fit inside the metal clips (from memory).
    2003 MK4 Golf 2.Slow (a.k.a the money hole) - 18' Lenso Type M wheels so far
  7. #27
    Feb 2013
    Quote Originally Posted by SasaG93 View Post
    Ah k thanks. Might as well get the full kit then.
  8. #28
    Nov 2013
    Goldcoast QLD
    im pretty sure i got a few metal clips spare , if you want i can have a look and you can have them ???
  9. #29
    Feb 2013
    Quote Originally Posted by aaron001au View Post
    Check pm's.
