Results 1 to 2 of 2
Thread: Parts needed for brake pad and rotor replacement on an R32 (excluding discs and pads)
    Jul 2009
    Melbourne, Victoria
    Hi all,
    I was wondering if anyone knows off hand the part numbers needed to do a full rotor and pad replacement on an R32. I already have front and back pads and rotors, I'm just concerned about the one time use parts like any clips or screws that I might need.
    Thanks
    VW .:R32 MKIV DBP 132/200 | VW MFD Ver G, DieselGeek SS Sigma, .:R Center Caps, ECS XAS CAI
    Apr 2008
    The only part other than the rotors and pads that you'd need would potentially be the screw that holds the rotor to the face of the hub, but that'd most likely already be on your car anyway, and you just reuse the existing ones.
    Well worth replacing your brake fluid at the same time as you do the rotors/pads. I believe a full flush only takes 2L of fluid, if that...
    Nothing to see here...
