Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Overheating on idle
    Jan 2009
    Brisneyland
    Thankyou JMac!
    I have crappy AC and overheating at idle or slow moving traffic. I'll be checking the fans and fuses ...
    How difficult is it to replace fans? Hang-on that sounds like I'm going to do it myself ... um how much time and cost of parts for someone like yourself to fix it JMac (would you prefer I contact you off forum?).
    Holster
    Jan 2009
    Brisneyland
    Should have mentioned it is a 2002 V5 AQN Bora
    Nov 2006
    Same thing happened on mine, had noticed the aircon not working for a couple of weeks, One day sitting in traffic it started to creep over 90degrees.
    Noticed fans not running when I jumped out, turns out the fuse 99gti mentioned just needed a jiggle.
    Jan 2009
    Brisneyland
    I've noticed the fuse holder is looking a bit tired (OK half melted). Hopefully a jiggle will be all it needs.
    How much is a new fuse holder and where's the best place to pick one up? (I'm in Brisneyland)
    Jan 2009
    Brisneyland
    YEEEEEEEEEESSSSSS!!!!!
    Just had to jiggle the fuse and she's all cool (pun intended).
    Still reckon I should replace that fuse holder - recommendations?
    Thank you all.
    Holster
    2002 VW Bora V5
    Camden, Sydney
    Quote Originally Posted by Holster View Post
    Thank you all.
    Holster
    The cheapskate aussie fix is an inline fuse holder bypassing the broken part of the fusebox.
    Or buy another fusebox from VW.....
    Jan 2009
    Brisneyland
    For anyone else out there with this problem
    Part number is 1J0 937 617 D
    $106.70 from VW.
    I might clean up the old one for now ...
    2002 VW Bora V5
    Apr 2008
    $106.70 from VW.
    That's not terrible. Might have to check the condition of my fusebox...
    Nothing to see here...
    Jan 2009
    Brisneyland
    Yeah could be alot worse. If mine is beyond reasonable repair I will get the part rather than try to solder in a $5 holder.
    I'm mostly relieved that I'm not up for new aircon/radiator or whatever else I thought it could be at the beginning.
    2002 VW Bora V5
