Should have mentioned it is a 2002 V5 AQN Bora
Thankyou JMac!
I have crappy AC and overheating at idle or slow moving traffic. I'll be checking the fans and fuses ...
How difficult is it to replace fans? Hang-on that sounds like I'm going to do it myself ... um how much time and cost of parts for someone like yourself to fix it JMac (would you prefer I contact you off forum?).
Holster
Same thing happened on mine, had noticed the aircon not working for a couple of weeks, One day sitting in traffic it started to creep over 90degrees.
Noticed fans not running when I jumped out, turns out the fuse 99gti mentioned just needed a jiggle.
I've noticed the fuse holder is looking a bit tired (OK half melted). Hopefully a jiggle will be all it needs.
How much is a new fuse holder and where's the best place to pick one up? (I'm in Brisneyland)
YEEEEEEEEEESSSSSS!!!!!
Just had to jiggle the fuse and she's all cool (pun intended).
Still reckon I should replace that fuse holder - recommendations?
Thank you all.
Holster
2002 VW Bora V5
For anyone else out there with this problem
Part number is 1J0 937 617 D
$106.70 from VW.
I might clean up the old one for now ...
2002 VW Bora V5
Yeah could be alot worse. If mine is beyond reasonable repair I will get the part rather than try to solder in a $5 holder.
I'm mostly relieved that I'm not up for new aircon/radiator or whatever else I thought it could be at the beginning.
2002 VW Bora V5
