Hi there , where you battery is check inside the black plastic cover , there is fuseable links in there. Most likely one of the 30amp fuses or the holder will be melted/open circuit. Now to fit a new one might fix short term but you may find that 1 or both of the fans are shorting. Normally the test for this is put the AC on and the condensor fans should cut in straight away, if not they will cut in and out on only 1 speed. This is a good indication the fans are gone. Mate 1st thing to do is look in the fuseable link area
Cheers and good luck, worst comes to the worst you can by pass the block connector and make your own
Jmac
