Be like Stan and do the 1.8T swap
http://www.vwwatercooled.org.au/foru...-8t-63249.html
Guys with economic cars want more power. Guys with power want more economy.
Just buy a motorbike to satisfy your need for speed or a cheap turbo jap car. It'll be cheaper and more fun.
It seems your heart is set on supercharging but chucking a turbo in would be the lesser of two evils.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Haha, I did look at Stan's build, so awesome. If only mine wasn't a daily, and I had a few more skills/experience in VW's.
Anyone got any ideas about the CAI and ECU upgrade vs the gearbox?
PS - That Golf GTI for $5000, gone. A guy bought it as we were both looking at it this afternoon. It was on carsales only just over 24hrs.
Dark Grey Mk4 Golf, 1.8T GTI conversion, APR stage 1, stock air intake, FMIC, 3" to 2.5" Exhaust, FK AK Street Coils, Black 18" (Avant Garde M310's ?), tinted tails, ...
Its just not worth doing anything to the 1.6L.... its a gutless single overheard cam...yet reliable and frugal ride... terrible base for modifications.
I have one and I would never contemplate modding it.
The colour of your car is indeed awesome.... what you want is a complete 1.8ltr conversion.
saw i got a nice mention, so thought i'd chime in.
I looked at the options as well - no one seemed to make a supercharger kit for the 1.6 - including in the USA
Similar deal with a turbo - the main issues being manifolds and engine management, engine and gearbox strength.
For all the mucking about and costs involved here were my options in most realistic order:
Buy a GTI....lol
or do the engine/gearbox/subframe swap i did. You also need to change the exhaust (different size and manifold flange), gear mechanism (rods vs cable), drive shafts (bigger axle shafts), compuer/ecu/ some wiring/ dont forget the intecooler, bigger brakes and other bits and bobs.
In the end i swapped the entire front subframe, exhaust, ecu, went big brakes, and other stuff. It wasnt too mechanically hard, but wiring and engine management were certainly the big two.
I also had excellent support from guys on the forum.
check the link in my sig for an idea of what was required.
If you got cracking and worked late - to do it the way I did, you might knock it over in a weekend if you had experience. The mechanicals took me about a week- I was learning and taking pics as I went - the pics slow it a fair bit.
it took 3 weeks to chase the ecu wiring , pinouts and fault find... most of that was chasing what the issues were, it took about 5 mintues to sort it once I found out what it was.
As for chipping and aftermarket tuning- it's pretty much a waste of time unless you have forced induction of some kind.
Another option would be do a 2 litre swap and get an aftermarket kit from the USA and supercharge it - get ready to spend about $3K +
the other thing about going 1.8t is that the aftermarket options are more plentiful by a long way
Happy to help in any way I can, good luck!
That's a pretty fair assessment. Unfortunately the 1.6 (and the 2.0 for that matter) are not a solid foundation to build on, there's too much that will need replacing that it's cheaper, quicker and easier to do something else altogether and end up with a better result.
If you truly love the body you've got (and it's a fantastic colour, no doubt) then the power plant swap would be the way to go.
If you want something that's even less hassles than this, then it's really a case of trading up to a 1.8T or something like that. If you find a clean, unmolested 1.8T, then it's quite cheap to get decent power gains as you're working with a factory turbo, so the plumbing and integration is all sorted out. You're also dealing with a platform with a stronger gearbox, bigger brakes and other go-fast bits factory fitted.
A quick remap and you're going to get another 10-20kW at least from a 1.8T and then if you want to bolt on bits, the sky's the limit.
Im going to go down a different path compared to most people , Ive built up a 1.6 mk4 engine before so I'll give some insight into it .
The 1.6 has a bore of 81mm and stroke of 77.4mm . Id say you could get away with running a 1.8 crank and boring it out to 82.5 mm . The engine I did was bored out to 82mm to save on cost (82.5 pistons were a bit more expensive) . Also the compression ratio is about 10.3 : 1 , with the right pistons you could increase this to about 11.3 :1 . So youd end up with about a 1.9l engine , and with the extra capacity it will help gain you more power .
Next you could work on the head , the valve size could be increased , a 260 cam could be used , exhaust manifold can be ported and mid muffler removed . The intake is tricky but the standard airbox is fine , just needs a bit better piping to the airbox .
If you could remove the air con it will help with power , as well as power steering . Pulleys dont help much with power , but you can use them as a last resort . Lightening the flywheel will also help with acceleration .
The gearbox Id sell (you'll get good money for it) and replace it with a cable shift out of a later A3 1.6 or beetle 1.6 .
So you'll probably end up with about 90-100kw once you do that , probably a fraction less than a gti , but its n/a .
Oh , please never disregard an 8V , with a hairdryer on them they make just as much power as the 20V . The biggest issue with the gti is your not going to be able to go more than gt28rs size turbo without going stand alone
Bug_racer supports the rebellion of the euro revolution
Firstly, Stan, absolutely awesome job!
So, how much would it cost to hire your services for a job such as this?!?! PM is fine
I can't believe it seems like it's down to all or nothing! So.. If I'm not going to do an engine swap, then I shouldn't touch a thing, at all? What about a new set of rings and a CAI? Or am I just supposed to put in a good drop-in filter and forget about it?
---------- Post added at 09:57 PM ---------- Previous post was at 09:40 PM ----------
Awesome response Bug_racer !
This is the exact sort of old school thinking that I'd wondered what had happened to. A re-bore, new piston & rings, etc., gold.
This could be a method for me! Know anywhere to give me a quote on that? Or even just a quote on the parts to get me started? (I have a mechanic).
Good honest feeback and different ideas.. Big thanks people, good stuff.. And thanks in advance to any new posters..
thanks for the kind words kenbot - i did the work, but had plenty of help. bugracer above was one of them
dont think it's all or nothing, I just found the most economical and practical solution that was right for me at the time
I'm sure you can tune up or modify a 1.6 - I just dont know how to do it well and aftermarket support is pretty thin.
Bugs option above is a good one if you want to keep and mod the 1.6 - but itcosts money, you need someone with engineering skills and time off the road. However you would end up with essentially a new engine and a pretty worked one at that.
My way was close to plug and play, but I got and engine with about 90K kms on it (still way better than the one i replaced). 1.8t agu has good aftermarket support.
It comes down to practicality, and which solution gives you what you are after - do you want power, tunability, add on bits, economy etc...
Easiest solution, is still to simply upgrade to a GTI - already done right, no bugs to iron out (I still have a speedo issue with mine...lol)
I did it the way I did as it spread cost over time instead of trying to find $$$ to upgrade to a better car all in one hit.
+1 turbo. big turbo that brings on boost at 3000rpm and just drive under 2500rpm power and economy all in one
