FK have a large range, some are budget to match with JOM, TA technix and similar brands.
Their higher range uses koni struts if i recall correctly.
Basically with coils you pay for what you get.
cheap will usually get you low, but ride can be average and might only last 25k km if you push them.
H&R, Bilstein, KW, usually dont go super low, but will ride more like a stock sports setup.
in saying that. I had TA technix, did 70k km or so on them. ride got better as time went on, went low enough for aussie roads, only sold them to upgrade
some cars need a new sway bar or end links at 30mm, others have got down to 50mm no worries.
the general rule is 40mm before needing to do work.
Keep in mind while you might only want to go 30mm lower then what the car is now, the car might have already sagged ~20mm from stock height over the years
Doubt they will fit, will hit the struts in the front. need more like 8.5et35 for stock/minimal drop. more like 8.5et30 for a 50mm drop up front.
18s is a good size for a stock or not slammed mk4, with a 225/40 or 215/40.
Otherwise 17s were a stock option if you want some chunky side wall
