Results 1 to 6 of 6
Thread: Once and for all - What is stock boost on MK4 GTI?
    Feb 2007
    Sydney NSW
    Hi Gang,
    I've searched, I've googled, I've asked and I'm getting different answers every time. Can someone tell me what the stock boost is on a 2000 model GTI?
    Someone told me 6psi, someone else told me 11, a mechanic told me 7, another forum is 'certain' it's 14!
    I thought it was 7psi but I installed a boost gauge and mine peaks at 11psi.
    (That's stock except for a full 2.5" exhaust / with dump, and a pod filter. So if it is 7psi, is it possible that an exhaust and pod gives an extra 4psi...)
    MK4 GTI | MK5 Sportline | 08 Audi S3
    Modify your ride with free DIY videos at www.mightycarmods.com
    Dec 2007
    I'm pretty sure i read somewhere on VW Vortex that it was around 8.7 . It may have been different depending on engine codes though...
    Here's the page i found:
    http://forums.vwvortex.com/zerothrea...66114#29935912
    It doesn't specifically list the AGU code specs, but all the 110kw spec engines seem to be listed as 8.7psi
    Sep 2007
    Prior to Gavin updating the software on my car, it would peak at 11, then drop back to about 9
    VW are pretty good at being ambiguous with their boost figures. The G60 was considered to be serviceable within something like 5 to 9PSI.
    I reckon the MK4 is good anywhere between 7 to 9/10 PSI. You have to understand how the boost is used by the engine and also how are you measuring it, is the gauge calibrated?
    If you try and get a reading in first or second you won't see as much, as if you ran in 3rd or 4th.
    Mar 2008
    Post
    Dont mean to hijack.
    What brand/model boost gauge do you guys recommend?
    Cheers in advance.
    Dec 2007
    Auckland, New Zealand
    ok after much research on the topic i think i know 1 of the major factors that causes the fluctuation in boost from 1.8T to 1.8T and that would be the actual Wastegate's actuator. I dunno if u guys have heard of this mod or not where u "crank" the actuator to increase or decrease the amount of boost that builds.
    http://forums.vwvortex.com/zerothread?id=2901711
    look at number 12. cranked wastegate.
    1999 Golf GTi - SOLD
    2005 Golf GTI (2 Door) - SOLD
    2014 Octavia RS400 Combi
    1997 Golf GTI (Daily/Track Hack)
