Results 1 to 3 of 3
Thread: oil light problems?? Some1 help
    Nov 2008
    Bass Hill, Sydney
    my oil light randomly flashes on .. however my oil is clean and at a good level????
    im unsure as to why its doing this.. im wondering if its safe to drive or if its a major issue??
    can any1 help?
    Feb 2008
    It could just be a faulty oil pressure sender unit (most likely, but it could also be a more serious problem (faulty oil pump). If you are handy with a multi meter, you just have find sender unit and then see if it id faulty, or you could just take it to a mechanic and get them to see if it is doing it.
    Aug 2007
    What engine you running?????? Could be a pressure switch and there is different ways to check them depending which colour it is. 0.3 bar switch is Brown, 1.4 Bar is Black, 1.8 Bar is white, 0.25 Bar is Blue. When checking the low pressure switches with a test lamp, the light will stay on till the revs are raised. High pressure will stay out till revs raised. Could also be the level sender faulty, this is common if you have one, although the light on the dash will be yellow, pressure will be red
    Jmac
    Alba European
