Hi all,
Is there a way of telling if it is simply a sump gasket leaking or a rear main oil seal? Both seem to show a leak in the same general area.
I have read somewhere as well as in this thread (can't remember where) that a leaking sump gasket is often mistaken for a rear main oil seal, the gear box removed only to find there was nothing wrong with the seal....
The reason I ask is mine is also dripping (maybe one tiny drop every couple of days) and after the amount I have spent on it so far, would hate to have to pull the gear box out again to fix a rear main....hopefully it is a sump seal instead.
Any ideas?
Thanks
