Results 1 to 10 of 11
Thread: oil filter stuck
    Jul 2005
    oil filter stuck
    Hi
    I have a year 2000 petrol 1.6 engine golf.
    The oil filter seems to be stuck on. Last time I screw it on hand tight.
    Bt now it jst seems to be realy stck. The normal oil filter tool I use with my
    other cars are too big for it.
    Is there any special trick or can u by a smaller oil filter tools for these.???
    tnx in advance
    David
    Aug 2007
    300mm Multi Grips and some elbow grease!!!
    Canberra
    I got one of these filter tools, 5th item down the page. Almost makes it too easy.
    http://www.metalnerd.com/cat05.htm
    Cheers,
    Snowy.
    Mar 2006
    If you have an old socket you can drill a hole through it from one side (about the diameter of your finger) to the other and thread a length of bicycle chain through. You will need to join the two ends of the chain together.
    Thread the loop of the bicycle chain around the filter and with the socket perpendicular to the chain turn the socket so it wraps around the chain and tightens around the filter (with the aid of a socket extension and ratchet).
    I made one 30 years ago as a kid and Ive never needed another tool for any vehicle.
    May 2007
    Moonee Ponds
    Curious Tuylar, do you have a picture of this mechanism ?
    Oct 2006
    Goto supercheap and buy a new filter tool they are pretty cheap just get sumthing like this: http://www.renault4.co.uk/technical/...ange-tools.jpg. If worse comes to worse u can drill a hole in the filter on both sides and stick a screwdriver threw it.
    Mar 2006
    Quote Originally Posted by qsilverza View Post
    Yeah sure its nothing complicated, will try and sort one of the current version tomorrow. Does everything even motorbikes!
    Nov 2006
    Quote Originally Posted by peedman View Post
    I've never owned a car with an engine bay open enough to get something like that around a oil filter and moveable.
    Dec 2006
    I've got one of those, and I can't get the filter off with that and there is no leverage !
    I had bought three filter tools, and it won't do jackall.
    But I had a filter tool similar to the one snowy posted but in plastic, and i killed the joint. Will get one of those in metal..
    -DIDZ
    Jul 2005
    Buy a strap wrench,I use one everyday and haven't come across a filter I couldn't remove yet.
    Peter
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
