Hi Alex. I've changed the oil on my 2003 Bora V6 4Motion enough times now. I use a 36mm socket - most specialist tool shops have these. I got mine from Total Tools (stores all over Australia) for less than $20 a few years back . You can suit yourself if you wish to take out the drain plug of the cannister (allen key). I do to avoid spilling too much oil when I remove the oil filter housing. I replace the plug every third or fourth oil change too so the o-ring doesn't perish. Also when tightening the filter a torque wrench is handy. Tighten to around 25Nm too much over this and you may crack the housing. You will probably use around 5.5 litres and use a decent oil - plenty of recomendations on this forum. I hope this helps.
Cheers,
David
