Oil change 4 motion help
Hi Bora 4-Mo gurus,
Im wanting to do a oil change on my rear end iv never done it before so what my question is??
What tools do i need to change the oil in the diff or haldex controller is there a filter and what oil is needed. Id like to give it a go myself.
Thanks for any info or ideas you might have.
Alex
Haldex filter and oil kit from ecstuning. The drain plug is small Allen key, get a new sealing washer. there's a special spanner for undoing the filter. You could buy one too? Goodfella has mine in Sydney which you could use if you live close enough. The diff has oil you can buy anywhere, forget the grade. Use a synthetic is my advice.
Thanks Gavin
Il have to hit up ecs for a kit.
Thanks vwsport for the link.
Should be fun.
All the best fellas
- You may not post replies
- You may not edit your posts
Forum Rules
