Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Oil Change
    Dec 2006
    Exclamation Oil Change
    Hi All,
    Since the VW booklet doesn't say how much oil is required to change oil with the oil filter - does anybody here know ?
    Cheers.
    s14s2a Guest
    Thumbs up
    Quote Originally Posted by DIDZ
    Hi All,
    Cheers.
    Depends on the model.
    The MkIV GTI requires 4.5lt on a oil change when you replace the filter.
    On that note, stick to genuine VW oil filters and try to avoid the repco etc ones as they may reduce the oil pressure in your engine.
    Good luck, and have fun keeping all of the old oil off the air con hoses!!!
    Apr 2006
    Hobart,Tas
    I use Mann filters which are the same as the original. And I definately agree, dont use Ryco or otherwise!!! Cheers, Andrew
    s14s2a Guest
    Thumbs up
    Quote Originally Posted by gtimk5
    Ive noticed a few people use the man ones.
    Where do you buy/order them from,are they cheaper than the 'slightly' over priced VW dealer ones???
    And what is the part #
    syncro Guest
    Are the dealer ones dearer?
    Apr 2006
    Hobart,Tas
    A lot of the better independent VW workshops would stock them, I am sure.They might have Hengst which are fine as well. I only stock Mann for the VWs though. Christmas Cheers, Andrew
    Dec 2006
    Talking
    I've just acquired a MKIV and looking to do all the little things I can do between the big services.
    Looks like I buggered up - will be taking it back for refund at Autobahn. The filter did look bloody small in comparison with the original...
    Now, to find one of those Mann filters.
    Have a Merry Christmas!
    gpk_gti Guest
    you can get the mann ones ,cheap st South Yarra parts at Alexandria Sydney.just got the contact details off the net,
    HSY Auto Parts41 Birmingham St Alexandria 2015(02) 8339 8339
    I change my oil every 5000kms,did the same with my Vr6 and never had any issues with the motor.Stops any risk of the dreaded sticky sludge
    Point Cook, Vic
    I get hengst ones from imparts. From what i understand hengst are the manufacturers of the OEM ones arent they?
    FOLLOW US ON FACEBOOK
    Oct 2005
    Melbourne - Greensborough
    We stock mann and hengst, sometimes genuine when vw ring us up and sell them cheaper.
    MK4 GTI (KO4, GIAC)
    VW Kombi Ute 2ltr EFI
    Audi 90 20V Quattro
Similar Threads
  1. can you change the clutch friction point?
    By BL33SU in forum Passat (B4 & B5)
    Last Post: 07-03-2007, 07:13 PM
  2. How do I change VR6 oil cartridge....
    By sukebe in forum Mk3 Golf & Vento
    Last Post: 07-11-2006, 09:37 PM
  3. Cable change gearbox conversion
    By twin eng, twin turbs in forum Restorations, Conversions and Projects
    Last Post: 25-09-2006, 10:48 PM
  4. Cam belt change on MK2 8V
    By aussieg60 in forum Mk2 Golf & Jetta
    Last Post: 14-12-2005, 07:58 AM
