Results 1 to 10 of 13
Thread: offset and stud pattern for 2002 mk4 2.0 se
    Mar 2011
    melboure, victoria
    hi guys looking at some rims and just wondering was thinking of going to 18s
    could anyone tell me the stud pattern and the offset i should use?
    also what tyres your running if your running 18s?
    Apr 2008
    5x100 is the PCD for all Mk4s, with a 57.1mm centre bore.
    Offset depends at least partially on the width of the wheels - somewhere between +35 and +38 is normal in the 6.5" to 7.5" width range.
    225/40R18 will maintain your aspect ratio (stock fitting on the R32 18" Aristos), but will make the car ride quite hard. I personally find 17" wheels to be a good compromise, I'm currently running 235/45R17 tyres (225/45R17 is stock on 17" wheels on the Mk4, but 235/45R17 tyres are considerably cheaper).
    Nothing to see here...
    Manaz has it all there.
    I previously had A8 reps 18x8 with 225/40/18. 17s and 18s are a good size for the mk4.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2011
    got a 2.0l gle at the moment. Running 225/40 r18x8.5 and have absolutely no problem
    Aug 2009
    no rubbing issues with 235's?
    if not i might go for them next time i need tyres (17x7.5 tt rims)
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    Quote Originally Posted by audi-tone View Post
    on 7.5s go 225/45s... IMO anyways
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Apr 2008
    Why?
    225/45R17s are quite expensive as they're a relatively uncommon fitment in the market here. 235/45R17 tyres are more common (common fitment on Falcon XR6 / Commodore SV6 for instance), and are a damned sight cheaper than their 225 width equivelent, and I've found that they've actually made my speedo more accurate (as compared to GPS) due to the very slightly higher rolling diameter.
    On 7" wide wheels I'd be cautious of going any bigger than 215 or 225, but on 7.5" wheels, 235 width is perfectly fine.
    Jan 2008
    Canning Vale, Perth, WA
    99% of aftermarket rims in this PCD are supplied in +35 offset.
    go lower (eg +30) and it will make the rims sit and look wider
    2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
    Quote Originally Posted by Manaz View Post
    Why?
    i just think they look a little big on a 17x7.5...
    Maybe its just the ones iv seen, as for bringing the speedo closer to where it should be, they will also give the wheel more protection from gutter rash i guess, and more grip. Didnt realise they were so much cheaper!
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Aug 2009
    thanks for the info fellas, have to try it next time i think. i like grip!
