DPE 19x8 on front, 19x10 on rear
17x7.5" tt wheels
hr racing 162's 18x8 all around
bora's already been posted so i wont repost
Audi TT 17s (resprayed)
17x7.5" tt wheels
I will give this thread a mighty old BUMP!
Instead of people posting up new threads all the time about "what wheels should I get" or "will these wheels fit" have a look in here first. I'm sure all you dudes love pic whoring so post up more pics of your car from multiple angles, wheels and tyre specs, and suspension mods!
There's threads on this on Vortex already but will be great if we can get one for the wheel rotations and specific Mk4 models we have in Australia.
this^^^^ iv been meaning to do one with a collection of photos and specs but havnt got around to it
if people layed it out like below, i think it would be helpful, as there are too many variables.
and if not all info is supplied its a pointless exercise.
Example:
Car: FWD or AWD
Front: 18x8.5 et30 215/40/18
Rear: 18x9 et30 225/40/18
Fenders Rolled: Yes
Fenders Pulled: No
Camber: Front No / 1deg extra in rear
Photo 1: showing height of car
Photo 2: showing poke/fitment in relation to the guards
It's been a while since I've posted.
I have the Oettinger 18" RE (3 piece which they don't make anymore)
Oettinger Sportsystems GmbH - Products
-DIDZ
Good posts by people but really need to know wheel offsets. Looking for new wheels for mine but struggling to work out what is best offset depending on wheel width.
Fuzion, what offset are those wheels?
Car: VW Bora V6 4motion
Wheels: Miro STP-1
Front: 18x8.5 et25 (after 5mm spacer) 225/40/18
Rear: 18x10 et15 (after 10mm spacer) 235/40/18
Fenders Rolled: Yes
Fenders Pulled: Rears only
Camber: Natural 4motion rear camber when it's lowered //----\\
Suspension: KW V1 with rear perches and adjusters removed
Notes: Obviously would look better dumped but this was the lowest I was prepared to go for a daily. Rear had a bit too much poke. Spacers were smallest I could use for the wheels to clear calipers, no problems hitting the strut with standard offsets.
Car: VW Bora 2lt FWD
Wheels: Audi A8 Flat5s
Front: 18x8.5 et30 (after 15mm adapter) 215/40/18
Rear: 18x8.5 et25 (after 20mm adapter) 215/40/18
Fenders Rolled: Yes
Fenders Pulled: No
Camber: Rear has additional 1deg each side (approx 2.5deg each side total)
Suspension: TA Technix. Helpers out in the front. adjusters, perch, and bush all still in the rear.
Notes: Perfect daily spec... proper sized and legal fitment, wheels would have sat inside the guards if my rear beam was centred (is now), looked like factory wheels.
Would have loved to go lower but rubbing the drivers side driveshaft on the body and wouldnt have lowered the rear anymore without the front going down because cars should have rake
Wheels: Genuine BBS LMs
Front: 19x8.5 et30 (after 25mm adapter) 215/35/19
Rear: 19x10 et32 (after 20mm adapter) 235/35/19
Fenders Rolled: No
Fenders Pulled: No
Suspension: TA Technix. Helpers out in the front. adjusters, perch, and bush all still in the rear and wound up 10mm.
Notes: Had these on at too stages, most of the photos are from GAF11 are with the arches unrolled and rear wound up 10mm
then back it up for Nats12 with the fronts rolled and rears wound down. made for fun times with 4 people in the car..
again, would have loved more lows but the front driveshaft was in the way.
the later photos:
Wheels: Custom Teledials
Front: 18x8.5 et30 (after 20mm adapter) 215/40/18
Rear: 18x9 et30 (after 15mm adapter) 225/40/18
Fenders Rolled: No
Fenders Pulled: No
Notes: Had these on at too stages again, early stages car was a bit higher and didnt have extra camber (Nationals 2011)
then the car was lowered all round and the shims were left in after the LMs. Arches were also rolled in recent times.
Will be improving the specs shortly
for reference, this is what a 215/40/18 looks like on a 8.5 and a 225/40/18 on a 9.
these fitments meet the manufactures spec believe it or not.
