Results 11 to 20 of 21
Thread: Number Plate
    Aug 2007
    Perth, Australia
    1991 BMW 318is RED E30
    Aug 2008
    Looks really mean
    Will do it over the weekend, and will let u guys know how it goes.
    Thanks for the help mate!!
    Tom
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
    Aug 2007
    Perth, Australia
    No problem. Be careful when you take it off, it might leave marks on the bumper
    Aug 2008
    exactly how did u do it??
    im getting a little bit nervous just pulling it off
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
    Dec 2007
    Brisbane, Southside...
    Quote Originally Posted by TomBrer View Post
    Took mine off tonight. You are going to have to pull off your front bumper.
    To do this there are approx 7 torx screws in each wheel arch you have to remove, 5 bigger torx screws behind and underneath the front grill, 4 torx screws underneath on the splash guard, a nut behind each of the passenger and drivers side lower grilles and finally the temperature sensor behind the lower grill on the passenger side.
    The front bumper should just pull off easy as now (as well as the attached splash guard. Just make sure your front grill is lifted up and out of the way (no need to detach it though) and the temp sensor is detached (you don't want to rip out the wires on that).
    Now make sure your number plate is removed and then hammer through the centers of the plate holder clip thingys (a hole punch will help with this). When these push through you will be able to then use some needle nose pliers to push through the clips and the plate holder should then come off pretty easy. You'll see what I mean once you have a look behind the bumper.
    A photo of how mine looks like. I've got a slimline plate coming so I'm going to get all the lovely holes filled. The 5 bigger holes are from the plate holder.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Aug 2007
    Perth, Australia
    Quote Originally Posted by Treza360 View Post
    Im not sure what you mean by that but my plate holder came off fairly easy, i didn't have to take the bumper off. A bit of patience and its all good
    Dec 2007
    Quote Originally Posted by balkanac View Post
    Hmmm maybe it will come off. But it'll definitely be easier to get the clips out by doing it from behind.
    I was pulling off the bumper anyway so yeah either or I guess then.
    Cheers,
    Trent
    Dec 2007
    So anyway, got my bumper and everything back on. No plate holder now. See my thread for more photos.
    Cheers,
    Trent
    Townsvegas QLD
    Heres what it looks like with a Euro plate.
    SLAM.POKE.TUCK.DROP.DOPE!
    Aug 2008
    looking good boys, originally i was just talking about sticking it back on where it was without the attachment, but now contemplating doing that
    you always find a way to go one better ay treza
    keep up the good work
    tom
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
