No problem. Be careful when you take it off, it might leave marks on the bumper
1991 BMW 318is RED E30
exactly how did u do it??
im getting a little bit nervous just pulling it off
.:MKIV R32:.
.:Reflex Silver:.
.:80th of 200:.
Took mine off tonight. You are going to have to pull off your front bumper.
To do this there are approx 7 torx screws in each wheel arch you have to remove, 5 bigger torx screws behind and underneath the front grill, 4 torx screws underneath on the splash guard, a nut behind each of the passenger and drivers side lower grilles and finally the temperature sensor behind the lower grill on the passenger side.
The front bumper should just pull off easy as now (as well as the attached splash guard. Just make sure your front grill is lifted up and out of the way (no need to detach it though) and the temp sensor is detached (you don't want to rip out the wires on that).
Now make sure your number plate is removed and then hammer through the centers of the plate holder clip thingys (a hole punch will help with this). When these push through you will be able to then use some needle nose pliers to push through the clips and the plate holder should then come off pretty easy. You'll see what I mean once you have a look behind the bumper.
A photo of how mine looks like. I've got a slimline plate coming so I'm going to get all the lovely holes filled. The 5 bigger holes are from the plate holder.
Cheers,
Trent
2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
So anyway, got my bumper and everything back on. No plate holder now. See my thread for more photos.
Cheers,
Trent
Heres what it looks like with a Euro plate.
SLAM.POKE.TUCK.DROP.DOPE!
looking good boys, originally i was just talking about sticking it back on where it was without the attachment, but now contemplating doing that
you always find a way to go one better ay treza
keep up the good work
tom
.:MKIV R32:.
.:Reflex Silver:.
.:80th of 200:.
