Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Not feeling so good
    Mar 2009
    Gold Coast, Q
    Not feeling so good
    Hi everyone
    Noob to this site.
    This has come about on my search for information.
    I have just yesterday put down a deposit on a 1999 Golf 4th Gen Rally GLE.
    It's Navy Blue and has done 151k. The price we agreed on was $ 7500
    This is to be my daughters 1st car (she did save and is paying for it herself).
    She originally was after a Corolla but there was nothing in her price range.
    I started looking around and found this car from a wholesaler. She was ok about it and said ok.
    But now friends tell me I'm mad, the cost to maintain and repair is enormous and that I should have looked at cars that are common and not from Germany.
    On top of this the car was advertised as a 1.8ltr when actually it is 1.6ltr and no log books (both of which I overlooked when I had a look at it. The test drive went well and absolutely everything appears to work.
    Have I stuffed up? Give it to me straight!
    P/s When is the belt meant to changed?
    Thanks for any responses
    St George/Sutherland, Sydney
    Welcome!
    The MkIV is a cracking car with what I reckon could be the highest quality interior you
    ll find in any hatch <$30k.
    Corolla is an excellent if predictable/forgettable first car. The Golf should be okay but I think there might be gearbox issues with the 1.6L, then again I'm no expert. I did my timing belts on a 1.8T at 70,000... some do it earlier, some later.
    Parts aren't the cheapest but find a good mechanic and you will be set.
    Good luck with the car!
    Apr 2008
    I'd opt out if you can, especially considering the false advertising. As said above, the 1.6s have a lot of problems with the gearboxes breaking making it a costly exercise.
    Parts can be expensive, but if you shop around they're usually pretty reasonable.
    If you can opt out, look for at least a 1.8 or 2.0 model. If worst comes to the worst, keep hunting for a 'rolla.
    2000 Mk IV GTI
    Sep 2007
    The 1.6's are unfortunately known to be a bit troublesome when it comes to gearboxes. Craig the German on here has done a couple now I think? (poor bugger!)
    Aside from that, the servicing/maintenance side isn't that much different to other Japanese/Euro cars we've owned
    Feb 2007
    Quote Originally Posted by Fridgy View Post
    Belts AFAIK are commonly done every 4 yrs or 90,000kms - not a cheap maintenance item either when parts & labour are calculated. The fact it was misleading advertising suggests that seller knows bugger all about the car, so anything they have said about it MUST be verified.
    The fact there's no books suggests its definitely a multiple owner car, and probably hasn't been looked after too well mechanically - people tend to keep records etc if they intend on keeping it regularly maintained and using that as a benefit when selling. Might pay to see if you can contact the previous owner to find out where they had it serviced at the very least.
    Along with the others, I've also heard about gearboxes being a weak link in the drivetrain.
    My advice: Steer clear. Would also be a good idea to let us know what the budget is so we can also have a look around for you and make an educated suggestion - servicing and maintaining a second hand golf is reasonable for cost, so long as it has been looked after in the past.
    Dec 2007
    Ermington, Sydney
    To be perfectly honest about European cars, I personally think that's a load of bollocks. Golfs and their parts are readily available in VAST majority on this forum (and it's information/links to websites) alone. There are also wreckers for parts and if you use your head and don't fix things with the first quote you get, I've found that a European car can even be cheaper to fix than cars without a bad parts reputation!
    Aug 2008
    Melburg
    I just so happen to have gotten the same car, '01 1.6 "AVU" engine... even in nav blu ......lol
    The parts for the 2ltr and 1.8 are ALOT more common in terms of golf engines, although dub parts are a touch more expensive across the board pricewise anyways..
    no log book means you have no idea really when the timing belt and water pump were done, you'd prob wanna look at a major service inclusive of these items typically equating to around $800 - $1200 cookies.. this is including labour btw
    timing belt is a biggie with interference engines such as this and is recommended replacement @ 60.000Ks and then every 60.000Ks thereafter by VW although it could be stretched realistically to around the 80-90.000 mark with a grandma driver or easy country KMs senario.
    Look I think I'd like to have gotten the 1.8 or 2 ltr of course but I'm a dude and at fear of being sexist will say very kindly that maybe your daughter is not such a power hungry person when it comes to getting from A to B....
    as far as a great car, YES YES YES, class all the way and the VW range just gets better from the golf up... I have not a regrett and at $7500 that is around the trade in price expected for that model and year, the KMs are a touch high so be wary of worn parts around the motor and sounds like knocks when starting the engine hot or cold.
    they have apparent "mysterious electrical issues" but I've never had an probs ...
    Didn't know about the gearbox issues,
    Anyone like to elaborate on that one?
    Dec 2007
    Ermington, Sydney
    Quote Originally Posted by thekraut View Post
    I think I'd agree on that advice too...1.6 may not be a great option. Keep looking if you can, and don't be disheartened about getting your daughter a golf. They're awesome!!
    If you end up with this car, in spite of what you feel is wrong. Don't despair.
    The Gold Coast isn't too far from Brissy and there are plenty of independent VW people you can go to. There are several on the forum, check the business pages.
    Aug 2008
    Melburg
    ...and yeah so agreed that NO LOG BOOK could be heading for big trouble.
    contact prev owner for sure!!
