Results 1 to 5 of 5
Thread: Non dealer source for rubber weather seals etc.
    Nov 2006
    Largs Bay, S.A.
    Just wondering if anyone knows of a reasonably priced source for some of the mk4 weather seals - ie. between the doors and the roof, window seals etc. as I'm getting some pretty major condensation and I've been quoted around $320 from Solitaire for just one seal where the window slides into the door. ( ie. so over $1200 for four of them alone )
    Cheers.
    Jul 2011
    I'll check on the web you should do the same,but to be honest genuine might be your only choice. Ill flick you done part numbers in the morning to make searching easier.
    Jul 2011
    Is this the one you need??
    Part numbers listed in the pic.
    Mar 2010
    Lesmurdie
    You can try ecs. Roughly $90 each. shipping might be a bit much but still ends up waaayyy cheaper.
    403 Forbidden
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Nov 2006
    Largs Bay, S.A.
    Quote Originally Posted by grtuned View Post
    Yes - they're the ones ... Apart from the dealer, all I've been able to turn up is second hand ones that are probably in a similar state to mine.
    Quote Originally Posted by Back Door Shenanigans. View Post
    That's a good idea - I'd forgotten about ECS. (... well blocked them out of my mind over crazy shipping costs in the past, but will check them out.) Thanks.
