Results 1 to 10 of 17
Thread: noisy starter motor
    Aug 2011
    brisbane
    noisy starter motor
    my son's 2.0l bora starter makes a horrible squeal, only when winding down, no issue when it's starting. is this easily fixed?
    Mar 2013
    Brisbane QLD
    what do you mean by winding down? as you are turning off the car or just after its fired up? if its just after its fired up and then the noise happens the starter motor will be sticking in and need replacement unit... VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Peregian Beach
    Probably a dry throw out bearing. My Beeza is currently doing the same thing. An easy fix apparently but the starter motor has to come out to be lubricated.
    Mar 2013
    Brisbane QLD
    yeh ive lubed up a few. worth a try. especially dsg gearbox cars but some have gone past and need a new unit...
    Aug 2011
    brisbane
    it happens once it's fired and disengaging. works as per normal.
    Jul 2007
    Brissy
    Mine does this, re conditioning the starter did not fix it. Lubing it made it better for a short while.
    My wife and I call it the "duck"
    I thought of replacing it about 8 years ago but thought I might see how long it lasts.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Aug 2011
    brisbane
    good call.
    i'll give the lube thing a go first
    mine makes that noise on and off.
    thought about replacing the motor, 5 years later the noise has gone and motor is all good still, no lube, no refurb.
    I just try to keep some money aside for that day when it does let go...
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jul 2007
    Brissy
    I have a budget for just these things, the $3k gearbox issues late last year cleared it out pretty much.
    MK4 GTI - Sold
    Annangrove, NSW
    The squeal is usually associated more common in manual gearbox cars.The reason being clutch dust dries out any lubrication in the starter motor itself and starter bush in the bell housing, always a good indictor of how a driver uses the clutch....change the bush when lubing the starter...always helps..cheers steve
