Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: noisy starter motor
    Aug 2011
    brisbane
    Quote Originally Posted by volksMuller View Post
    The squeal is usually associated more common in manual gearbox cars.The reason being clutch dust dries out any lubrication in the starter motor itself and starter bush in the bell housing, always a good indictor of how a driver uses the clutch....change the bush when lubing the starter...always helps..cheers steve
    your probably on the money steve. the car has 200k on the clock and the previous owner spent 2k 2 yrs ago replacing clutch, flywheel and drive shafts, also the syncro's on a couple of gears bite a bit
    Jul 2007
    Brissy
    Quote Originally Posted by ericcs View Post
    Change the gearbox oil.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Aug 2011
    brisbane
    even if it looks ok?
    Jul 2007
    Brissy
    How would you tell it it looks OK ? There is no dipstick, just fill till it overflows.
    I changed mine a while back, after that shifts were a lot smoother, especially at high revs into 2nd.
    I used Redline MT 90. I even have about 700ml left over should you need some. And the 17mm hex tool to remove the drain bung.
    MK4 GTI - Sold
    Aug 2011
    brisbane
    Quote Originally Posted by JustCruisn View Post
    thanks for the advice. is the oil you use different to normal gear oil?
    another question, is the engine oil vw specific (2.0l) like my other son's TD T5?
    eric
    Feb 2010
    Launceston, tas
    mines squealed ever since I bought the car about 2 years ago, still works fine. Have forever been wanting to pull it out and grease it. Just never seem to find the time, apparently its very common with our mk4 starters. Bit embarrassing when starting with a heap of people around. Haha
    Mar 2013
    Brisbane QLD
    eric
    generally vw have two oils . petrol engines and diesel engines.. but it depends on what type of TDI your sons T5 is.. if it has a DPF filter or not makes a difference to oil used...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
