Results 1 to 10 of 25
Thread: Noisy Reverse gear
    Mandurah, WA
    Quote Originally Posted by balkanac View Post
    So straight cut gears are stronger than helical cut ones?
    MUCH MUUUCCCCHHH Stronger.
    You can get a Straight cut box with Synchro's too so you don't have to rev match at all. In our WRX we have done 1st to 4th so for highway driving, you can go to 5th and have the quietness of the Helical cut.
    Camden, Sydney
    Just dont go flat out backwards and change the oil for a special gearbox oil that quietens noisy gears.
    Its the same box internally as Golf 3s and 2s, all of which have noisy reverse gears.
    gold coast
    Smile
    Quote Originally Posted by DAN682 View Post
    just to let you now helicel gear are acctully stronger as there is more tooth because of the angle
    straight cut are just better to ingauge (ie. change gear quicker)
    rex boxs just break due to people smashing them it to gears
    so when they get the straight cut it allows them to change quick with out as much risk of it breaking
    (]/_ O _____ O _\[)
    "'(O8o)=\X/=(o8O)
    [__|========|__]
    May 2007
    Jimboomba. QLD
    G/box oil
    Hi all,
    went to change the g/box oil to see if it made any difference to the noisey/knocking reversed gear...found I couldn't undo the drain or refill plugs...needed a 17mm male socket...not something I had in the tool box.
    have got one now from Repco, cost $18.50 but can now do the job this arvo.
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    TassieGTi Guest
    If its knocking in reverse there is damage to the teeth.This will eventually result in failure.020 boxes from the mk3 on had a very weak reverse gear set and its a common problem unfortunately.
    May 2007
    Jimboomba. QLD
    Reverse
    Hi all,
    Well changed the oil in the g/box last night.
    Gearbox is now smoother than ever before, the shifts are slicker than ever before but the reverse is still the same.
    I can assume that from previous posts, this noise is common to the 020 g/boxes.
    What is the solution, wait until it goes bang and then rebuild or is there a common fix that could prolong the life of the g/box?
    It has made this noise for at least the last 35000km and possibly before (previous owner) but has gotten louder recently.
    Can I still just drive is gently in reverse and get a reasonable life out of it or is it likely to go bang in the short term?
    What is everyones experience on this?
    Should it go bang or I decide to rebuild prior, who is recommended in brisbane?
    Thanks and sorry for all the questions?
    Nov 2007
    Melbourne, Australia
    Quote Originally Posted by craig_the_german View Post
    Hi all,
    Does it do like a bank noise when you put it in reverse or it is just whinning noise as you reverse ?
    If the former, don't worry. I made mine much quieter with Redline MTL gearbox oil, that is the best there is.
    If the first, let it go bang and then rebuild.
    2001 Audi A3 1.8T manual | Giac stage 1 | 3" custom down pipe |TT brake carriers and disks | Eibach pro kit | S3 wheels |APR R1 valve
    2002 BMW M3 6sp manual | Macht Schnell stage 1 intake | Rogue Engineering power pulleys | CSL OEM Wheels | Rear LED lights
    Camden, Sydney
    If its just clicking, just be gentle going backwards and it will be sweet.
    I have experience of 020 gearboxes rebuilding and the reverse gears are weak, especially in those Mk3 and 1.6 Mk4 boxes.
    Its actually the same gear used in the Mk1 4 speed boxes and these never wear out, different steel, or less gears in the gate? I dont know.
    I have known em last ages with noisy reverses and it probably wont hurt the rest of the box when the teeth sheer of the reverse gear. I`d wait for other symptoms before getting it rebuilt.
    Jan 2008
    Quote Originally Posted by chris. View Post
    Are you for real? I'm an engineering student, and I've studied the manufacture of straight and helical cuts, particularly in diffs -and i can tell you that you're completely wrong
