Results 1 to 10 of 16
Thread: Noisy brake discs
    Jul 2010
    Elanora Heights, Sydney
    Noisy brake discs
    Hey all,
    My Bora is wearing RDA slotted front discs and Remsa pads (as are many others, thanks to GSL) but lately they have become pretty noisy.
    I do get a bit of surface rust on them, I dont mind that but the noise makes me uncomfortable. I dont feel anything through the pedal or steering wheel, so I'm not *too* concerned. Unfortunately my car is only used (generally) for the 15m commute to work and back daily and the noise is there for pretty much the entire drive.
    Its an *almost* grinding noise - not a proper grinding noise, but a hard rubbing that is *almost* grinding. I go down Mona Vale road (if you know it) which ends with a big hill and going down there is the worst.
    Anyway, could just be normal, I know it is normal for the stocker rotors to be noisy, but not sure about the RDA's (I know they are not as good as DBA's but should still be better than stock.)
    Thanks guys.
    Eltham, Victoria
    I've been getting this the last week or so as well, I've got Greenstuff pads on ventilated and slotted discs (brand escapes me at the moment) and the noise matches exactly with your description.
    I also don't know what the reason is and would welcome anyone to chime in with possibilities.
    Mar 2010
    Lesmurdie
    I'd say its just most likely dust or crap on the pads/disks. My brembo's started doing it after the track day so that would be due to glasing them over (which can happen down hills if you ride the brake). I'd try bedding in your brakes or a couple of really hard stops to clean the pad and rotor. Failing that im fairly sure you can buy anti squeal stuff.
    Edit: have to ask, You checked your brake pads made sure they have meat?
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Jul 2010
    Quote Originally Posted by Back Door Shenanigans. View Post
    I havent checked them, but the pads and rotors only went on maybe 2000 k's ago. I can't do any brake mashing atm because my ABS is engaging early. Ergh, brakes suck... Wish we didnt need them.
    Aug 2007
    Perth, Australia
    you should be able to pull the ABS fuse (which will turn off the AWD system too) and try breaking hard a few times.
    Ift hat doesnt help you'll have to take the calipers off and put a lot of anti squeal paste on the pads
    1991 BMW 318is RED E30
    Jul 2010
    Yeah good idea.
    Thanks.
    BTW, thought you guys might like this ...
    Heh , apparently I have a noisy bra!
    Jul 2007
    Brissy
    Did you replace the brakes your self ? Did you use anti squeal on the back of the pad? Is the rotor flush to the hub, sometimes you need to remove rust with a wire brush. Check the rotor retaining bolt is tight too.
    Removing pads and roughing them with sand paper or concrete can remove glazing. Is there a build up of pad material on the rotor, maybe on the back side so hard to see.
    Your abs issue may be caused by a loose sensor at the back of the hub.
    Jul 2010
    Quote Originally Posted by JustCruisn View Post
    I did do the brakes myself, yep. The front wheels have been off a fair few times lately, and I did notice the retaining bolt was loose on one of them last time. I'm scared to use loctite or something on that bolt as its only a philips head and could be a bastard to get out.
    ABS issue is *probably* due to either the G200 lateral sensor which has been throwing intermittent errors, but could also be caused by a loose abs sensor as I had to get a broken wire on the front passenger side fixed recently.
    How would the glazing occur? Lack of driving? Its not driven on weekends, but it is every other day, even if just for a 25k round trip.
    So, looks like this weekend, I'll take both front wheels off, ensure the rotors are flush and retaining bolt is super tight, I'll remove any excess rust and might even apply some anti squeal.
    Thanks for the help!
    Jul 2007
    Brissy
    Dont use loctite. I had a funny noise and found the bolt missing. A new one was only 48 cents and is a torx not phillips. The rotor can move a bit without the bolt. If not seated correctly you can get vibrations and other noises.
    Aug 2009
    sydney, NSW
    glazing can be, like ssaid above, from riding the brakes down that hill you mention.. best thing i'd suggest is fix the ABS up before it could give a dangerous change.. then give the brakes a new bedding in.
    a couple of hard stops from 60km to 10 should give you some new meat.
    goodluck!
