Results 1 to 10 of 19
Thread: noisy air con
    Dec 2007
    noisy air con
    Hey guys,
    The hot weather must be getting to the golf. Both last when driving home and today when driving around at lunch, I had the climate control on, and all was good until after about 20 - 30 minutes of driving there was quite a loud whirring noise. Basically at idle you don't really hear it but, it happens as you rev the car, or you are downshifting through the gears. When i turn the air con off the car sounds fine.
    Could the air con unit need some basic maintenance or is the compressor on its last legs?
    Dan.
    Sep 2008
    Townsville
    Could be a bearing in the compressor or maybe the compressor clutch.....
    Have a look at the comp with the car running ,see if the clutch is working how it should and if it is and the sound is comming from the comp then i say at a guess its a bearing. I take it that the system is still cold tho ?
    Dec 2007
    Yeah, it's still blowing cold.
    When i get home this arvo, i'll have a look at how the compressor is going.
    Thanks,
    Dan
    May 2007
    Moonee Ponds
    Hope you get it solved Dan, Roof racks worked a charm nice to meet you even if it was in a carpark for five minutes !
    Got my exhaust back hope to fit it tomorrow !!!
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
    Aug 2007
    Mate the bearing in the serpentine belt pulley might be worn. This gets loaded up when the Air is on. Have a listen in that area
    CHeers
    Alba European
    Dec 2007
    Quote Originally Posted by Jmac View Post
    CHeers
    Thanks for the replies. I think this might be on the the money. I had a listen last night when i got home and there was definitely a mild squeak/whistle coming from that area at idle. Should this be easily repaired? i.e. I'm hoping they won't want to replace the whole compressor... either way, i'm going to call about it this morning and book the car in....
    Quote Originally Posted by qsilverza View Post
    That's awesome mate. I can't wait for my 42DD exhaust to turn up as well.
    It was good to meet you too.
    Dan.
    St George/Sutherland, Sydney
    Re: Air con.
    Mine seems to get a second wind so to speak about 2-5 mins into a drive. It blows cold okay then later WOOOOSH it really gets going and blows harder into the cabin. Not sure why, but could yours be doing the same???
    Aug 2007
    Just to add mate the belt tensioner is a complete item. Loads around though, i would be tempted to pm Golf Loon he will have one for sure. The pulleys come off seperate but can only be bought complete, go figure. He may still have a good pullley
    Alba European
    make sure you don't have one of your vents at like 95% closed position.
    that was the most succesful fix i've ever made when i heard my aircon whirring, and found out it was just because the vent was causing the whistle!
    Dec 2007
    Quote Originally Posted by Mr Messy View Post
    Re: Air con.
    I'm not sure about that mate. Mine fluctuates a bit but only when it's set to auto, as you'd expect... Even before this noise developed, it has felt like the air con has been stealing more power from the engine than usual. A mechanic is checking the pulley bearings for me on wednesday and we'll see how we go.
    Quote Originally Posted by McDub View Post
    hehe....nah, mine is definitely making noise from outside the car.... It's pretty noticable when it happens.
