Results 1 to 5 of 5
Thread: Noise from left front
    May 2012
    I recently lowered my suspension and drove it last night for the first time since. When I take off there is a creaking noise but goes away once in motion of about 30km up. I jacked the left side up and turned the tyre a degree back and forth. I held the cv shaft and thought it could be the inner cv, BUT I then jacked the other end and it did the same thing. Worse nightmare...... could be my diff in the g/box or can that be normal? The sound could be louder due to the lowered suspension. Anyone give me good news........
    how much lower?
    could be strut bushes or sway bar bushes moving around now its in a different position
    Eltham, Victoria
    Quote Originally Posted by Eman View Post
    Strut top bearings? Mine creak every time I leave the garage in the morning.
    May 2012
    How low: The 18 inch rim is sitting on the arch. Lowest point on the car is less than 100mm to the ground. I greased the rubber top shock mounting which took away the clunking noise when turning. Ye maybe I will have to grease the other rubber bushes under the car. Any other thoughts ?
    careful about greasing them... have heard it makes them wear quicker.
