Results 1 to 7 of 7
Thread: Noise/ clunking under car- 99 mk4 GTI HELP!!
    Feb 2015
    Lilies Mountains NSW
    Hey all,
    Recently bought a mk4 gti and I absolutely love the thing but it's got some noises coming from under the front of the car and I can't figure it out. Neither can my mechanic.
    At first we thought it was the lower control arm bushes as they are well worn and the bushes had huge cracks, so replaced the whole lower control arm on both sides. Noise still there.
    My mechanic has been over the whole underneath of the car and tightened everything. Still can't find it.
    The only noise we can find is a small noise that appears to be coming from inside the steering rack. Could this be the cause?
    I can feel and hear the knock/ clunk when I drive, it can be felt both in the passenger foot well as well as the drivers when I take my foot off the clutch and place it on the floor.
    Please help. What am I missing? What could it be?
    Thanks all
    Strut tops bushes or bearings.
    Sway bar bushes or links.
    Control arm bushes.
    Noticable More at slow speeds?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Steering Rack Tie Rod End, Inner Uni's are worn, common problem
    They wear out and allow a lot of play, which causes the Knocking noise you are hearing.
    VW Golf M2 GTI Red
    VW Golf M2 GTI Red
    VW Golf M4 GTI Red
    Jan 2014
    Narangba QLD
    when driving where does the sound come from?
    I get a clunk that is actually the drivers door hinge, when i spray some WD40 or silicon spray on them it goes away for a while.
    swaybar bushes often creak a lot while driving when worn?
    could be a dud shock that is knocking about ?
    Jul 2007
    Brissy
    I had excessive noises when turning and when the weight of the body shifted, it was the ball joints. Right side was the worst, had them changed and it is a lot quieter. I still have a small noise on the left side sometimes which has me baffled.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Feb 2015
    I'll pass all the above onto my mechanic and get him to check each one out and get back to you guys.
    Thanks heaps!
    Apr 2013
    Similar issue in my car, have just replaced the strut rubber tops and no more clunking.
    Turned out the left strut was moving side to side as both rubbers had compressed 4-6mm.
    all better now
    Quote Originally Posted by kimmeh87 View Post
    Thanks heaps!
