hmmm.....................me to!
Check to see if the drivers door trim lamp & dome lamp turn on/off when door is opened/closed. If not sure check this with the other doors.
I think you may have a faulty drivers door lock assy inside the door.
If so I'd replace the regulator clamps as well (with steel ones) from VW.
Jaimo.
06 Jetta/09 Pirelli/DSG
08 T5 BPC/Auto
08 Caddy Maxi life TDI/DSG
12 Up!.
yeh my drivers door is stuffed too... light dont turn on once the dorr is open
MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
My mk3 had a similar problem on playing around with the actually assembly it seemed to actually be stuck and that was it.
Living close to the ocean ? IF yes, rust in the electrical switch is the answer..
2001 Audi A3 1.8T manual | Giac stage 1 | 3" custom down pipe |TT brake carriers and disks | Eibach pro kit | S3 wheels |APR R1 valve
2002 BMW M3 6sp manual | Macht Schnell stage 1 intake | Rogue Engineering power pulleys | CSL OEM Wheels | Rear LED lights
