Results 1 to 8 of 8
Thread: No more beep???
    No more beep???
    My car used to beep at me if i did something stupid like leave the lights on and take the keys out of the ignition. It doesn't anymore. Can this be activated via vagcom? Anyone know why it may have turned off?
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    gpk_gti Guest
    hmmm.....................me to!
    Apr 2006
    Nth of Nowra.
    Wink Beep?
    Check to see if the drivers door trim lamp & dome lamp turn on/off when door is opened/closed. If not sure check this with the other doors.
    I think you may have a faulty drivers door lock assy inside the door.
    If so I'd replace the regulator clamps as well (with steel ones) from VW.
    Jaimo.
    06 Jetta/09 Pirelli/DSG
    08 T5 BPC/Auto
    08 Caddy Maxi life TDI/DSG
    12 Up!.
    Thanks - I'll check it out!
    Aug 2007
    doncaster, vic
    yeh my drivers door is stuffed too... light dont turn on once the dorr is open
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
    Sep 2006
    Australia?
    My mk3 had a similar problem on playing around with the actually assembly it seemed to actually be stuck and that was it.
    Nov 2007
    Melbourne, Australia
    Living close to the ocean ? IF yes, rust in the electrical switch is the answer..
    2001 Audi A3 1.8T manual | Giac stage 1 | 3" custom down pipe |TT brake carriers and disks | Eibach pro kit | S3 wheels |APR R1 valve
    2002 BMW M3 6sp manual | Macht Schnell stage 1 intake | Rogue Engineering power pulleys | CSL OEM Wheels | Rear LED lights
    I used to live right on St Kilda beach - hardly an ocean but I'll have a look anyway....
