Results 1 to 10 of 14
Thread: No Indicators/Wipers
    Sep 2009
    Frankston
    Hello All,
    I hate to make my first post a bad one, but unfortunately i'm having some troubles with my recently acquired Bora 4mo.
    I bought this car without the aftermarket sound system fully working, don't ask me why... and needed to run an accessories feed to the boot for the amps. I found a feed at the fuse box and soldered on to it without cutting anywires, then heatshrunk it etc. The feed that i used was the same one as the head unit was using for its ACC feed.
    I ran my cable to the amp and voila! sound! a few hours later i went for a drive and found that i had no indicators. No fuses were blown. Hazards still worked.
    I've been researching this on the net for a few hours now, and have now discovered that the wipers do not work either.
    Its seems that the same fault has been had on the UK VWAudi forum and has been described as one of two things:
    1.X Relay Failure
    or
    2. convenience control module needs to be unplugged and then reconnected.
    This is where the trail goes cold...
    Does anyone know where i might find either of these two parts?
    Thanks for your help.
    Ryan.
    Nov 2006
    Brisbane Qld
    The wiper relay is under the drivers side dash on the relay plate - it is the only double size relay plugged in (big rectangular one)
    The indicator relay is integrated into the hazard switch itself (if you are looking for that)
    The Comfort Control Module is the black box straight up above the relay plate under the dash which is screwed onto a bracket on the steering column - it will have a 23 pin blue plug in it.
    You have to pull the big cover off the side of the dash where the fuses are before you can remove the right hand under dash knee panel. Then you can get to the relay plate and CCM.
    You will also be pleased to then see that there are accessory feed terminals already mounted under the relay plate for you to use when adding stereos etc.
    You just need to add a proper sized fuse in any feed from them (as the terminals are only fused with 40 and 50 Amp fuses which are on top of the battery, so way too high for any circuit you might add)
    Camden, Sydney
    Do the hazzard flashers work?
    If you disconnect the wire you added, does it fix the problems??
    Aug 2007
    Perth, Australia
    take the positive terminal off the battery and leave it off for 20-30 min. that will reset the whole car. See if that helps
    1991 BMW 318is RED E30
    Sep 2009
    Frankston
    Hazzards Work Fine.
    I disconnected the wire i added to no avail.
    Sep 2009
    Frankston
    Quote Originally Posted by balkanac View Post
    I've just tried this and had no luck...
    This would have the same effect as disconnecting the CCM directly, yes?
    Anyone got any other ideas?
    Sep 2009
    Frankston
    Quote Originally Posted by graeme86 View Post
    Yeah i saw that there when i was looking for the fault. Very Handy. Thanks for the tips.
    Jun 2008
    Ringwood, Victoria
    rhyno, I had a similar situation to you when I bought my last car. It had a very dodgy install done by the previous owner and the only way I fixed it was to rip out all the wiring he had done (the old twisted wires and electrical tape trick!!) and replace it with a much better and safer setup.
    If I was in your shoes, I would do this:
    1) Disconnect your entire stereo and see if oyur wipers and indicators come back. If not, something has probably gone pop and either your relays are fried (rather unlikely) or a fuse has gone (not always visually evident).
    2) JB HiFi, Jaycar etc. They sell stereo install kits, buy one of these and start from scratch.
    3) You mentioned that you were running an ACC wire to the amps that you spliced into a wire from the fuse box. From the numerous installs i have done, you are meant to run a constant power, either from a "hot" wire or directly from the battery, this coupled with a big in-line fuse. This and your ground wires, especially with multiple amps, should be no smaller than 10mm diameter. The switching for the amps should be provided by your signal or remote wires.
    4) If things still aren't working, then there is most likely a fault in the way the head unit was originally installed, not unlikely either, depending on the installer they would have either used a proper ISO plug or just cut and joined wires. Hopefull the first option is what they did!
    Sep 2009
    Frankston
    Quote Originally Posted by gavs View Post
    1) Yeah, Its bad, there are joins all over the place where wires were too short, etc. I intend to replace all the wires as i get the time.
    2) I'll look into this, i take it that the kits are just the correct plugs?
    3) I ran a fused cable (10mm) (rated to 120 Amps) from the battery, the ACC feed is an excitation wire to turn the amp on with the ignition.
    4) The head unit worked fine, i just needed to get a feed to the acc on the amp, i will replace all the cables anyway becuase it's simply unsafe.
    When I opened the fusebox for the first time i noticed that there has been something in there at some stage and its caught fire. My guess is the fog lights weren't run off a relay initialy.
    I think i will test all the fuses with a multimeter and see if one is broken, it seems to be a Convenience Module Fault, I'd say its not getting any power. I'll test it after work and let you know how i go...
    Jun 2008
    Ringwood, Victoria
    The kits come with the wires you need in different guages, they come with cable ties, eyelet fittings, a big-ass fuse for your hot line, RCA plugs etc, I see you're in dromana so pop up to the JB in frankston and have a look, if you go mid-week you might actually get a guy in the car audio section that knows his stuff and might be able to shed some info on your dilemma too.....
