Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: No clutch - Broken plastic clip.
    May 2010
    Quote Originally Posted by JustCruisn View Post
    The white bit is very tight. I tried just now to remove the white bit an reckon it would break if put on too much force.
    I'd say you need to just drive that shaft in between the legs and push it into the hole at the end. It should be lubricated too.
    Thanks.
    At this minute I'm absolutly ropeable.
    My tip for the bush (white plastic clip) into the shaft on the master cylinder: Heat a pot of water on the stove.. chuck in the white clip for about 30 seconds, pull it out and flare out the "legs" with some needle nose pliers, then repeat a 2nd or third time if necessary.
    Place the legs around the shaft and spread them with your index figures (I used both - Uno what they say, two hands for beginners!)
    Whilst spreading the legs, push on the back end with you thumbs until it goes click! Done!
    Still can't get the fu@#ing spring on! I've tried everything.. cable tied the spring, used a screwdriver pushing on the white end of the spring.. nothing! I can't for the life of me work out how I can't get it back on when it came on and off so easily before.
    I'm ready to smash everything in my immediate radius with the biggest hammer I own! Why oh why is this so fi@#ing hard to do?
    I'm seriously considering pulling out the whole pedal box (disconnecting the master) to get the spring in, then just bleed the clutch.
    All of this because VW used a flimsy POS sheet metal without sufficient welds.
    In case you can't tell, I'm seriously pissed off.
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
    Quote Originally Posted by Speed View Post
    Thanks.
    its a huge PITA man, we had my gfs dad and I in the car arranging it (yes you can get two people in the drivers side... lol)
    from memory we gave up and did the spring first, and left something else loose and added that after...
    even my mechanic with the tools said its a huge pain
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jul 2007
    Brissy
    Its a bit tricky with the pedal box out too. I could not imagine doing it in the car.
    Getting the hydraulic line off the cylinder is a little tricky, bleeding is easy enough just make sure the bleed line runs lower than the nipple.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jul 2011
    The white clip and washer need to be fitted in the clutch pedal. Attach the clutch pedal using the shaft. Then you need to press down on the clutch until you hear a click. Be careful it can all come undone if not done correctly. And you could break the plastic clip again. It's difficult if not experienced. Done a s$& load in my time.
    Sep 2008
    Launceston
    Hey mate, below is a a copy and paste from a thread i started about the same issue (search "clutch peddle issues" for the whole thread). Its a little bit of a fiddly job but its pretty easy once you know how. I had to do this job twice and the second time i ended up buying the VW speciality spring compressor for $50 to make my life easier.
    By the time i got home after work it was already dark so i had to undertake this lovely job with the use of a 12v light.
    For anyone who is doing this for the first time, i thought i would write down a couple of points i learnt along the way.
    All you will need is a cable tie, a pair of pliers, 13mm socket, and a 13mm ring spanner or shifter.
    - First of all, do it in the daylight.
    - Like JMAC said, tack some extra welds on your new pedel or repair the old one. This way you shouldn't have to play around with it again.
    - After you have pulled the peddle out compress the clutch spring with your hands and use one cable tie to hold it. Put the cable tie in a spot you will be able to snip with some pliers when it is back in location.
    - Make sure you put the white plastic piece back on the shaft that connects to the master cylinder before you put the peddle back in.
    If i had known these few point i probably could have had this job wrapped up in 30mins.
    Nick
    Not sure if this will help but may as well post it anyway. Clutch Pedal Replacement
    This is one I made when I did mine, I had the intention of a detailed thread but at times got pretty pissedand lost the care to document it. May help a little though if you haven't already finished.
    Sep 2012
    Safety Beach, VIC
    Mine has just done the same thing, does anyone know where I can buy the necessary parts or know any part numbers for the white plastic clip, the black cover and I think ill need the metal retainer as well. I've managed to fix it temporarily by getting a small bolt through some existing holes in the pedal and drilling the broken nylon so its holding for the moment but i would like to get it fixed asap.
    Jul 2012
    Jacksons should stock them - it happened to me not long ago and they had the stuff I needed.
