Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 155
Thread: New ride: '02 MK4 GTI
  1. #111
    May 2012
    Quote Originally Posted by leighaus View Post
    Hey Jake, will keep you up to date on progress.
    Ill be away in bali being tortured by cocktails and massages for 2 weeks unfortunately, so may slow progress.
    I just used VCDS lite with the cheapo cable. you can still get all the codes, you just have to use a chart to work out what each one is. does the job for my needs really.
    Not sure who did the dyno to be honest, the tuners had it dyno'd for me. Somewhere in dandenong at a guess.
    where did you find the chart mate??
  2. #112
    Aug 2011
    melbourne
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
  3. #113
    Melbourne, VIC
    Re: New ride: '02 MK4 GTI
    Hi how are you going with your fault finding, I'm running logs and researching a heap keen to see if if you've had any luck?
    The daily
    White 2001 Mk4 GTI
    GIAC stage 1 - ECS stage 1 clutch & 14lbs Flywheel - 42Draft/Remus Exhaust - APR R1 dv - N75J - K&N
  4. #114
    Aug 2011
    melbourne
    gday mate.. havent looked at the car in any way for the past couple of weeks. Been super busy with work (yay shift work) and have no money to get it to a workshop. I looked all over the car for any leaks, couldnt find one..
    Im going to check my timing to make sure thats all hunky dory before i take it to the workshop. Asides from a leak, or a MAF issue, i just dont know what else could be robbing so much power.
    Its definately not fuel, as i know that feeling.
  5. #115
    Melbourne, VIC
    What should the timing be?
    What did it feel like when fuel was the issue?
    I'm hopefully changing the o2 sensor soon (tomorrow with any luck) I did a maf and tb clean yesterday but noticed a split CV boot before I could run some wot logs.
    What blocks are you measuring?
    The daily
    White 2001 Mk4 GTI
  6. #116
    Aug 2011
    melbourne
    i havent had a fuel issue on the gti, only on my silvia.Iit is like a surging of power, rather than a complete lack of it, especially under load.
    I need to look into timing, but i think im due for a timing belt, so ill look into costs etc to see if its a worthy DIY or better off getting someone whose done it 100 times to do so.
    Im not measuring any blocks (no VCDS, only lite for faults) at this point. pretty strapped for cash with house deposit etc, hence its taking me a while.
    the 02 sensor should improve your fuel, i doubt its going to give you a lot of power back, unless your ecu is going into limp mode due to an 02 fault being logged.
  7. #117
    Aug 2011
    melbourne
    ran a boost pressure test at home today... highlighted a cracked dipstick tube, not much else.. ill replace that then do it again.
    Also raised the front about 2 inches... can fit 3 fingers between guard and tyre now.. crazy... as im heading a drive and might have to take some slightly offroad tracks to get where im camping.. hopefully dont get stuck.
  8. #118
    Aug 2011
    melbourne
    hell yea, took long enough!! looks awesome in person, light was fading. Need to give them a detail and the car too. The front is still jacked up from when i went camping (4x4 rake yeaaa)... I'll wind the coils down and hopefully the helper doesnt foul on the front rims. Ended up fitting 215/40/R17 to 17x8 ET38 and ET39.
  9. #119
    Nice.
    Get some more pics when its back down to earth
  10. #120
    Aug 2011
    melbourne
    New hoses installed. Just gotta to the TB to IC and pancake to IC piping tomorrow, then ill change the coolant sensor and give her a run.
