Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 155
Thread: New ride: '02 MK4 GTI
    Jan 2014
    Alice springs, NT
    Very nice one
    Mods to date: GFB BOV t9025, 17"x 7 avanti drifters, clarion touch screen head unit, PD160 air flow, cone in box.
    Aug 2011
    melbourne
    So over yesterday and a bit today, i did:
    Fuel filter
    oil and filter change
    spark plugs (colder for the tune)
    Timing belt kit (ultimate)
    Acc belt
    Water Pump
    Thermostat and housing
    pulley upgrade
    valve cover gasket kit
    All in all, it went pretty smoothly. First time doing a timing belt and it wasnt too bad. didnt take too many photos as theres a few guides floating around. I used: VWVortex.com - Ultimate Timing Belt DIY!!
    Jacked her up, ripped off the imported jap wheels,
    the task at hand: a lot of **** in the way of a small space
    stock pulleys (note the size orientation of the balancer to power steering)
    Cover is off. What a bitch that was for no reason. Then it just almost fell off..
    whack a 16mm spanner on your acc tensioner, then stuck a 3mm allen key in the locking hole. The acc belt basically falls off.
    Mark your old belt at TDC, including orientation.
    The infamous engine mount (pictured in the centre).. Constantly in the way, but not too bad.
    Stock belt on the left.. One side of the teeth was starting to wear a bit, no cracks at least. And a gates kevlar racing timing belt to the right... It's blue, so you know it's good
    The old plastic water pump: Had only just started letting go, which was good Replaced with a german metal impeller.
    Tried to bicycle chain the belt on, however ended up successful putting the water pump on last.
    the new lightweight pulleys. Note the size orientation has now swapped. Means your engine doesn't have to work as hard to turn your alternator, water pump, etc = free power.
    Thermostat housing with thermostat snug in behind. That bottom bolt was a bitch. I'd probably remove the alternator next time. My thermostat was starting to fail to open, so glad i changed this over.
    And all re-assembled ! happy days.
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
    Mar 2009
    Wagga Wagga
    Good job tackling yourself. I was too worried about doing it myself on the bora.
    Had a chance to drive and notice any difference from the pulleys
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Aug 2011
    melbourne
    Cheers guys. It's a big job abd a fiddly job, but it's not that hard. I've been swinging spanners on my own cars for a bit over a decade and didn't fond anything too difficult. i was just super anal about getting the timing right
    The car feels like its picking up a bit faster and it's running really really smooth. Probably a combo of the pulleys and the different plugs. I'd say maximum 4-5rwkw difference. On my bum dyno.
    I'll be taking my car to a real dyno soon and getting the forge wastegate actuator fitted.. so it'll be interesting to see what she pulls
    Mar 2009
    Wagga Wagga
    Aug 2011
    melbourne
    Slip of the tongue. I've owned a couple of performance rwd cars prior to this and just finished night shift before this job. Brains a bit cloudy
    Wish it was awd though, it's no fun when the roads are wet. Have to baby it so much.
    Mar 2014
    beautiful car bro!! very clean and great work!!
    hope to see that babe around
    take care!!
    Aug 2011
    melbourne
    thanks mate...
    Yesterday replaced the coolant flange (where the temp sensor sits) as it had lost its seal to the block. Nice easy job.
    Then drove my newly fixed car to work to have the bloody clutch pedal assembly let go. I can luckily still use my clutch, but it has fallen to the floor a couple of times. Think ill just take it to a workshop and get it done quickly.
    Aug 2011
    melbourne
    Another ecs order about to hit the front door..
    Replacing 3 door lock modules... Bitch of a job ahead!
    Pics to follow
