How is the ride with them on? A lot of bouncing?
as with any coilover setup, you have to be more conscious of the road and poor road conditions. Especially if you want them to last. i dont mind them at all, my missus doesnt even say anything. People who havent been in lowered cars normally mention its a bit bouncy.
'02 GTI (clicky) - REFLEX SILVER -
VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
got some 3M CF vinyl (wich is actually textured) to redo the interior, and decided to have a play first (as i cant open my pass door, so interior will have to wait to do it right). Test came out nice, i really like it. theres a bit where i cut a little too close and a tiny smidge of chrome can be seen, so ill redo it in a bit once the interior is done. breaks up the front of the car. hopefully it weathers well. it should be good for around 5 years.
That's pretty original man, looks the goods, too. Hope it holds up well
cheers mate, everyone whose seen it in the flesh really likes it.
Took out the crusty champion plugs and put $100 worth of ngk platinums in. Also drained, flushed and refilled some fresh coolant. All in preparation for the tune I'm about to get.
Will re upload all my photos that got deleted in this thread too.
Edit - also ordered a dog bone mount from powerflex to fix my tramping issues which will only get worse with more power .
Viezu tune and dump pipe ordered, awaiting install date.
powerflex dogbone mount going in today to help deal with even more wheel shudder that will come with power.
and bought some more grip:
~6 weeks away
dogbone bushes was all easy until i had to compress the new bushes to get the bolt going. took a while. ended up using two spring compressors which worked a treat once i finally realized the bloody nut was in upside down causing it to be 1mm out and start cross threading.
all done. underside of dash vibrates on idle now, which ill have to fix up, but other than that, its pretty good. feels a bit firmer in the way it handles power, but nothing drastic. good cheap mod.
POWERFLEX!
artsy ****...
fixed all broken photos in previous posts
ordered some new taillights, which ill have in 2 weeks.
- You may not post replies
- You may not edit your posts
Forum Rules
