Page 5 of 16 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 155
Thread: New ride: '02 MK4 GTI
  1. #41
    Jan 2009
    blankedy
    Might not be limp mode, sounds like its ready for a tune... I don't know the Mk4 GTI, but same engine in my car. I believe 5-7 PSI for stock is normal. Having changed the diverter, swapped the N75 and cranked the wastegate may not have affected the boost levels much / at all.
    I don't know your experience with VAG's, but the 1.8t ECU needs a flash or to be swapped to get the most out of it.
  2. #42
    Aug 2011
    melbourne
    you may be right, i was under the impression 7-8 psi was stock for the mk4 gti. That information, coupled with having installed an N75J and cranking the wastegate made me think i shouldnt be maxing out at 5psi.
    Im not well versed in the VAG scene, i have come from a 5L v8 and an sr20det silvia prior to the GTI. Maybe i was just expecting a little more from the GTI. A smoke test and scan is the only way to know.
    If i find out the car is all clear then i will book in a viezu tune, ive already spoken to the local workshop who will do it.
    i guess the last possibility is the k03 is on its last legs. However the car has never been modded and was a family car previously. :\
  3. #43
    Jan 2009
    blankedy
    A simple clearing of the codes, releasing the adaptation of the ECU (disconnecting the battery for 10 min and discharging) may give it a little more kick. It could be a little aged, it could need the throttle body re-alligned, it could need new spark plugs and be pulling timing, it could be a lot of things.
    A smoke test is probably not a bad idea, I've not done this but if you go for it (is it cheap?) make sure they check it for a higher boost than you have now (assuming thats an option).
    The 1.8T is a different beast after a tune. I'd be thinking about the intercooler, an uprated diverter valve (the OEM ones are not really designed for 20psi) and checking the service history is good. New spark plugs dont cost much, you can go a little cooler if you are going to be tuning shortly.
    A visual check of the vacum pipes coming off the intake manifold only takes a second, but a good mechanic who knows his way around the Mk4 GTI will pick up on little things that you and I wouldn't know to look for. Some of the 1 way return valves near the block get pretty hot and after 10 years may be leaking / blocked.
    I'm not trying to be an expert, but think you should alleviate the basic possible issues before replacing gear and playing with the wastegate .
    Once you have any issues sorted and the tune on, you'll be a happy with the performance. For a while...
  4. #44
    Oct 2010
    northern beaches nsw
    Leigh I have the same car (same year and colour too).VERY SLOW STOCK.I drove it stock for around a year then Revo,d.
    Night and Day mate.No other mods whatsoever and so far everything sweet.It seems to me a lot of people change all their bits out before seeing how the stock parts (DV etc) go.As yet my car runs perfectly and the tune only cost about $800.Better on fuel too.
    MK4 GTI Revo Stage 1 / BFI Dogbone Mounts / 710N DV
  5. #45
    Aug 2011
    melbourne
    thanks for the reply bullsta/noone.
    Car is running pretty good at the moment for what it is i guess. still believe the boost should be up a little, but eh.
    Put new spark plugs in, was definately due for some, got champion premiums. Pretty damn expensive plugs i must add.
    Did a scan using VCDS Lite last week also. pulled up a few fault codes.
    [quote]18010 -P1602 -Power Supply (B+) Terminal 30 Low Voltage
    00515 -Camshaft Position Sensor (Hall Effect Sensor)
    01262 -Wastage Bypass Regulator Valve -N75[/quote
    first one may be due to disconnecting the battery. I also had a loose Neg terminal on the battery, so might have also thrown a fault. The other possibility is my ignition barrel is screwing up. Research showed that was a major cause for that error, and my cigarette lighter is not working now. Even though there is power both sides of the fuse. Ive even taken the cig lighter out and tested the wires to be dead, so i know its not just the unit.
    Also ordered a genuine bosch camshaft sensor from the states which should be here just before xmas.
    In relation to the n75 fault, it may be due to disconnecting the n75 when i changed it to a n75J, or maybe the J will just always throw faults.
    So I need to reset the fault codes and see what reappears now.
    ---------- Post added 07-12-2011 at 11:06 PM ---------- Previous post was 04-12-2011 at 09:56 PM ----------
    bought some new rims... wont be on for a little while though.
    ---------- Post added 09-12-2011 at 06:41 PM ---------- Previous post was 07-12-2011 at 11:06 PM ----------
    also had my FORGE induction pipe arrive yesterday. so will fit that soon too.
    ---------- Post added 12-12-2011 at 08:16 PM ---------- Previous post was 09-12-2011 at 06:41 PM ----------
    was reading "turbo problems with no error codes" and it was said
    Quote Originally Posted by Bug_racer View Post
    Its a pressure actuator , requires pressure to open wastegate . If you crimp the hose [from the n75 to wastegate nipple] you should be able to overboost the turbo
    i tried this and the boost freely went up just over 10psi.
    with only getting 5psi without that hose crimped. Im going to assume that i dont have a boost leak, and my issue is the wastegate / turbo?
    i understand the turbo wasnt actually boosting to over 10psi.. but are my assumptions right? my boost gauge is tapped in on the hose between the manifold and the fuel rail
    ---------- Post added 14-12-2011 at 05:20 PM ---------- Previous post was 12-12-2011 at 08:31 PM ----------
    camshaft sensor arrived from the states today... will fit that now. probably fit the Forge TIP tomorrow night. (btw i hate how this keeps editing the same post).
    ---------- Post added at 08:58 PM ---------- Previous post was at 05:20 PM ----------
    FUAAAAAK YEA! FINALLY! A ****ty little camshaft sensor being replaced has fixed the GTI. So damn happy right now. pulling around 9psi, dropping back to 8psi instead of hitting 4.5 and then just not making any more power. Such a relief. I honestly was pretty unsure of the results, but im smiling again.
  6. #46
    Aug 2011
    melbourne
    fitted the TIP last night. A somewhat simple job turned into a bit of a **** of a job for a few reasons.
    heres a pic of my new rims also... arrived thursday. will start stripping and repairing them soon.
    18x8 Audi A8 rims. 1 in good nick, 3 are rashed up. Going to strip, repair and paint.. Have to decide what colour to go however. I dont want to go black, as you lose the rims in the wheel well, but i have to think of something that will go well with silver and not stand out like dogs balls too much.
    Also bought a new headunit:
    clarion CZ301E
  7. #47
    Jan 2009
    blankedy
    Nice.
    You should still consider a chip (ECU reflash), it brings out the best in the 1.8T. IMO the 1.8T's are just comuters without it (especially with the extra torque thats going to be sucked up by those heavy rims).
  8. #48
    Aug 2011
    melbourne
    With the exhaust, the new TIP, the N75J and the cranked wastegate, its actually running "zippy enough". its not going to maul anything, and to be honest im a bit beyond that. Ive had a few powerful cars in the past and at this point im not going to chase more power. If things get boring in a year, ill reinvestigate chipping the gti.
    Installed the clarion headunit today. Pretty easy job really. Remove the digital climate to get access, insert 4 cut up coat hangers and pull it out. Had to switch a couple wires over, but with Golfs and Clarion being ISO plugs, its a breeze. Very happy with how it looks and i think it suits the factory look in addition to my boost gauge. Will get a night shot of the whole dash when it gets dark..
    -edit- still havent been able to find the source of my problem with no cig lighter power. theres 12v either side of the cig lighter fuse, but nothing at the plug.
  9. #49
    May 2010
    Chip it !!! you don't know what your missing.
    Is well worth the money.
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
  10. #50
    Dec 2007
    Auckland, New Zealand
    leighaus: Have you gone for a drive in a chipped mk4 GTI? i too was in the same boat as you thought car was pretty decent power wise until i went for a drive in a mates chipped GTI, needless to say I'm now chipped and as a bonus i now get even better mileage out of a tank of gas
    1999 Golf GTi - SOLD
    2005 Golf GTI (2 Door) - SOLD
    2014 Octavia RS400 Combi
    1997 Golf GTI (Daily/Track Hack)
