Results 1 to 7 of 7
Thread: A new owner's stupid questions......
    May 2007
    Jimboomba. QLD
    Hi everyone,
    well it has been almost a week now that I have owned the mk4 (GL 1.6 man)and now I have some stupid questions to ask. For those of you who are experienced owners, they may seem silly and easily explained but there are a couple of things that are puzzling me....so here goes....
    1. The rear hatch window has a wiper on it, does it have a washer as well and if so....where do you put the water in...I have looked and looked and can only find the bottle for the front washers..or does that one do both?
    2. The drivers door has what appears to be a tiny LED right next to the door lock button (the one at the top of the door). What is this for and should it light up? Mine doesn't.
    3. Lubricants. Is there a list of lubricants? Gearbox oil etc and change intervals? I have read the owners manual and it explains all about the service indicator on the dash but gives no indication of what to use in the gearbox etc.
    I appologise for the seemingly silly questions but I just like to know these things.
    As for owning the Golf...I should have bought one years ago......
    syncro Guest
    Quote Originally Posted by craig_the_german View Post
    Front bottle may do both. Should be in manual
    This indicates the central locking is locked. Should flash when button is pressed on remote.
    Gearbox oil has no service interval.
    Yes.
    May 2007
    As above... Any futher questions please let us know!
    May 2007
    Jimboomba. QLD
    Stupid questions
    Hi everyone,
    Thanks for the answers...seems silly but when you don't know....
    One last thing...mine doesn't have remote central locking, just central locking with the key, does that mean that the little LED shouldn't light up for me...it doesn't.
    Thanks again
    Jun 2007
    I have a 2000 1.6 manual (since new).
    1) yes, the one water bottle is used for the front and rear washers.
    2) The LED on the door should light up, as described in the manual. First lock, it deadlocks the doors (ie can't open the door from inside, or unlock using the driver's door lock controller) and lights up. Lock again with the key, and it undeadlocks the doors and the LED stops flashing.
    cheers
    Just a small thing in case you didnt already know, when you leave the signal light on when turning off the engine, it will turn on the park light.
    I didnt actually know this one so I was a bit freaked out when it first happened. haha.
    …me too!
    Jan 2007
    another freaky thing you may experience is when you play with the powered right side mirror, the left mirror will move magically too. So best to change right first and left later.
