I forgot about the negative camber I have on the drivers rear side, so the top of it tucks in a little. Damn camber.
I might have the same sort of problem, my right side sits real nice with awesome fitment. Then the other side either has less poke or sits higher. Not sure what I can do about it, maybe 5mm spacer on the left side?
can get the bushes on the rear beam replaced and have the rear beam professionally aligned...
I thought about running a 2-3mm spacer, but would be better off just pulling/rolling the guard out a bit to try and match it.
its only when the car is lowered and there is proper fitments that it can actually be seen
woooah! this looks great! so thats where my old wheels went? they look killer in black! and on a bora!
wheels on the previous car. IMO looks MUCH better on the Bora!!!
Are you planning on keeping your BBS?
'76 Mk1 LS
'04 Mk4 .:R32
'09 Audi S5
looks nice dude.
unfortunately with these things, the less clearance and bigger the wheels, the lower it should go.
lower.... bags.....
nice work.
