My recollection is that whether the engine is hot or stone cold the low speed fan will come on if the air conditioning is on. If it doesn't then it sounds possibly like the old low speed fan resistor problem. If you search this forum there is plenty of advice and recommendations for how to fix it. What used to happen was the low speed fan would stop working because the wire inside the fan motor breaks. Then when the engine gets hot enough, the high speed fan should come on but that would send a power surge through the fan control module and eventually blow it.
A guy in the U K I think it was, came up with an external resistor board which allowed you to continue to use the existing (broken) fan ie not have to purchase new fans. I did the modification on my Bora when my fans stopped working when it was about 4 years old. The car now is 16 years old and has 350,000k's on it and it still has both of the original fans in it.
