Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: New Clutch
    Aug 2007
    doncaster, vic
    New Clutch
    has anyone had to replace their clutch.
    just want to find out what were the signs for the clutch to be on its way out.
    i think mine is finished..
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
    Nov 2006
    Put it in 5th up a decent size hill and floor it. If it starts slipping (revs rise faster than speed) then you know its on the way out.
    Aug 2007
    doncaster, vic
    yeh it was doing that on the fwy... but on take off 1st and 2nd it didn't slip as much
    Aug 2007
    Perth, Australia
    its gone mate, and needs replacing. Get it done ASAP so you avoid damaging the flywheel
    1991 BMW 318is RED E30
    Aug 2007
    doncaster, vic
    thanks guys,
    would it now be a good idea to get a heavy duty button clutch with lightend flywheel
    Dec 2007
    Melburg East VIC
    i'd get ecs stage 1 kit (vr6 clutch with g60 single mass flywheel).
    costs less than oem clutch even with shipping from the states.
    no chatter either. check your clutch fork, mine was bent n cracked
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
    Dec 2006
    Clutch is on the way out.
    I'm probably looking to change from the single flywheel to a 228mm dual mass (if I can find one). Not finding the torque I was getting with the lighter flywheel..... or maybe it's because everything else in the driveline is crapping itself.
    -DIDZ
    Aug 2007
    doncaster, vic
    whats the approx cost of an aftermarket clutch
    Quote Originally Posted by DIDZ View Post
    I chucked a DMFW away about a month ago after going solid on my A3. Got a lightened ABF FW from Golfloon and bought an uprated clutch from Extreme clutches.
    Cost about a grand all up. I was going to get the kit from ECStuning but figured if I had problems it would be a lot harder to deal with the states over someone in town.
    I have had trouble with the bite point being really low, tried a new slave cylinder which didn't fix it, in the end I had an extension machined up by a mate to lengthen the rod on the slave cylinder by 5mm. It's still low but ok to drive.
    The pedal is little heavier and it doesn't drive as smooth but I knew it wouldn't be perfect. The DMFW removes a lot of shunt when going on and off the throttle.
    Dec 2007
    Melburg East VIC
    i've got a 225mm dual mass (approx 22lbs) which is the stock one in 1.8t (02J tranny).
    are saying that you want to change from a single mass to dual mass because you are not finding the torque you were getting with the lighter flywheel.. Single mass flywheels are usually lighter.
    what car is the 228mm dmfw from? s3/tt or stock vr6?
