using a electronic boost controller + chip
hey guys hope this is not stupid, but i just wanted to see your thoughts on using an APEXI AVCR together with a chip.
A few boys from the vortex forum have used them and according to what i have read they love it.
If you dont know what an avcr is, its basically a electronic boost controller that also gives you info on you engine i.e speed, rpm, boost (psi), and a bit more.
is this a "its not worth it" mod?
or would it be worth while.
The reason i'm thinking about one is because an electronic boost cont will hold boost alot better and stronger than what it usually does.
i dont intend on boosting the lil thing to 24psi.
What do you think?
MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
