Results 1 to 10 of 16
Thread: traction control light wont turn off
    Mar 2011
    Inner West, NSW
    Just to clarify, i drive an 8L S3 so maybe you mk4 gurus could shed some light on my issue...
    the other night I was driving the car home and about halfway into the trip the traction control light decided to turn on; I did not manually press the ESP button at all. Now every time I drive the car, the TC light comes on as soon as I start the car without me pressing the ESP button.
    I changed the MAF sensor with a brand new one (as thats what other forums have said to do) and that did not fix my problem. I don't have direct access to a VCDS but could it be that my haldex has finally let go?
    I plan on getting it scanned asap but yeah, just trying to figure out possibilities.
    Jul 2007
    Brissy
    Maf has nothing to with the esp.
    Maybe you have a bad wheel speed/ABS sensor, or the sensor disc has gunked up.
    I had a loose speed sensor once and it made abs kick in all the time, no traction control on that car however.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Mar 2011
    Inner West, NSW
    true true, I'll give them a clean and see if that changes anything.
    ABS light isn't on so I think it could do with a scan.
    Jul 2005
    Had many an S3 with a bad maf and esp light on at same time,new maf and no esp light.Strange but true.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Best find someone with VCDS next and see what the cars says is wrong. ESP and TCS won't work if the ECU can't see what is happening with the engine, ie what the airflow through it is.
    Other failures can cause the same lights to come on though, ABS failures, no wheel speed at one corner or the YAW sensor.
    Mar 2011
    Inner West, NSW
    Cheers Gavin. Yeah a scan is what I'm going to get done - no more guess work and it'll give a straight answer. Thanks for the input fellas
    wheel bolts tight?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2011
    Inner West, NSW
    wheel bolts tight?
    hahahah, that was the first thing I checked lmao
    Which car fid you do the brake upgrade on?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2011
    Inner West, NSW
    Put the 4pots on the S3; R32 gets no love
