Results 1 to 8 of 8
Thread: New Alloy wheels
    Dec 2007
    South East Melbourne
    New Alloy wheels
    found a good deal for 14" Alloy wheels for my MK4 golf.
    Questions is referring to spec of the 6Jx14 rim, can the current 175/80/R14 be fitted in without replaced?
    what I am thinking is to swap the rim only this time, and change tyres next time service with wider tyres like 185/70/R14.
    don't know how 14" rim look like (when fitted), as I rarely see a 14" alloy wheel on MK4. there are also 15" wheel deals for MK5, not quite sure can be fitted on MK4 or not.
    cheers,
    Apr 2008
    The Tyre & Wheel Bible says a 175/80R14 tyre will sit on rims from 5" to 6.5" wide.
    http://www.carbibles.com/tyre_bible_pg2.html <- Search for "An ideal rim-width calculator"
    So you should be OK.
    Nothing to see here...
    Dec 2007
    Quote Originally Posted by Manaz View Post
    Fantastic! thx
    May 2007
    Jimboomba. QLD
    14" wheels
    Hi,
    I have 14" alloys on my MK4 and I am running 195/70/R14.
    Hope this helps
    Pete
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    Dec 2007
    Thanks for the info. I think I pretty much gonna keep the tyre till next service.
    BTW, how is the oil leaking, fixed?
    May 2007
    Jimboomba. QLD
    oil leak
    No, I think the rear main is still leaking but it's not too bad so i'll leave it until it gets much worse.
    I have a couple of other leaks at the moment, the fibre washer on my sump plug is leaking a little and I seem to have developed a bit of a leak (more of a weep) around where the gearbox selector shafts go into the gear box but not sure until I wash it all down at the weekend (before the cruise).
    Jul 2009
    Geelong, Victoria
    i have 185/75/14 on mine
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Dec 2007
    update
    eventually get the wheel updated.
    Yokohama S306 195/70/R14
    New VW R14 RIM.
    Not the best looking, but perfect fits my needs -enhanced performance from steel rim and a new set of new tyres.
