Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Need urgent help, new golf won't start.
    Jun 2011
    no the car isnt cranking at all, just giving me a dash warning beep, and these lights EPC Engine Service
    i have studies the book, the IMOBILIZER light is NOT on and apparently isnt halding it back.
    i assume the EPC light i have read is the engine management light is what i assume is stopping it.
    Aug 2007
    Quote Originally Posted by Lemon View Post
    Ok firstly forget the immobilser altogether, even if it were locked out it would still crank and start momentarily then cut straight out so forget that. it would even start if the cluster was removed and that has the immob in it, but would cut out, so the key is crank and start. Is the fuse box on top of the batt good?? even when they can appear good they can be making and breaking inside, check the output of the fuse links are in fact 12v.
    If it isnt cranking it cant be EPC either mate, its losing a start feed or a main feed hence check the output side of the fuse links
    Jmac
    Alba European
    Jun 2011
    With no electrical testing equipment, is their something I can test or visually check, appart from obviouse unconnected things :p
    Adelaide hills, SA
    Not much really, however these days you can get the digital voltmeter for less than $20 and that would help you a bit.
    Also it's a handy tool to have.
    Jan 2006
    Lowood Qld
    how old is the car??
    in my Cordoba the ign lock is worn and wont start if the Key aint in a special angle and pressure due to wear!!
    Jun 2011
    Thanks fr all the help, it turned out to be a bad earth, tiny bolt, fixed now
    Jan 2012
    Tamworth, NSW
    Had similar problem with B7 Passat... it was a fuse... but it took four weeks to fix... had to get it trucked to another dealer who knew what they were doing. Glad to hear you got it going.
