Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Need a new throttle body?
  1. #21
    Apr 2008
    Illawarra, NSW
    I'm back at work now and have had heaps on outside of work so haven't had a chance to look at it the last week. I've got a mate trying to source a throttle body in Europe as they are too expensive here. Gavin's been giving me some ideas and I'm still hopeful of maybe being able to get to the bottom of what's wrong with mine, but I need the car running so can't take too many risks with it until I can secure a replacement. I'll post up a few more details of the tests I've done in the next day or so.
    Previously owned 2001 Golf GTi. Sold to forum member
  2. #22
    Apr 2008
    Illawarra, NSW
    Here's some more details on the tests I did on the two units I've got. Not sure how interested people are going to be in this, but it might be useful to someone one day.
    Note that the pin numbers here do NOT match the numbers physically visible on the throttle body - for whatever reason the wiring diagrams are numbered differently. The pin numbering I used matches the wiring diagram and is as follows:
    Code:
    1 3 5 7
    2 4   8
    The missing pin is Pin 6.
    Pin Functions
    1. actuator +12V
    2. actuator GND (idle control + cruise) - (switched ground for actuator control)
    3. throttle closed = pin 7 / open = ∞ - only detects cable/manual operating of throttle
    4. +5V
    5. Throttle position sensor - measures position of throttle valve
    6. Not connected
    7. GND
    8. Actuator position sensor - measures position/angle of electronic actuator - not moved by throttle cable
    Wiring Diagram Snippit
    Pin Measurements
    Test Unit 1 is the non-cruise unit 06A 133 063 G (Audi A3)
    Test Unit 2 is my suspect cruise control unit 06A 133 063 F
    Check throttle open/closed switch:
    Measuring with a multimeter resistance between pins 3 and 7.
    Test Unit 1: At idle: 0.6Ω. As soon as I moved the throttle: open circuit
    Test Unit 2: At idle: 0.6Ω. As soon as I moved the throttle: open circuit
    Check throttle position sensors:
    Total resistance: Between 7 and 4 (doesn't vary with throttle position)
    Test Unit1: 0.95kΩ
    Test Unit2: 0.95kΩ
    Check throttle valve potentiometer:
    Between 5 and 4:
    Test Unit 1: At idle: 0.71 kΩ increased to 1.45 at 3/4 throttle back to 1.40 at full throttle.
    Test Unit 2: At Idle: 0.76 kΩ increased to 1.51 at 3/4 throttle back to 1.43 at full throttle.
    Check throttle valve positioner potentiometer:
    Between 8 and 4:
    Test Unit 1: At idle: 0.69 kΩ
    Test Unit 2: At Idle: 0.65 kΩ
    These readings don't change as I manually move the throttle, they will only change as the throttle is electronically operated (this sensor measures the movement of the electronic component of the throttle).
    Check Throttle Actuator:
    Between 1 and 2:
    Test Unit 1: 2.9kΩ
    Test Unit 2: 23Ω
    This last test showed the most significant difference between the two units - Gavin has also measured his unit and found it to have 2.9kΩ as well, but it is also a non-cruise control unit so I'm still not sure whether this is the result of a different rated actuator in the cruise control unit or a sign of the underlying problems with mine. Would greatly appreciate it if someone with a cruise control unit would be able to measure theirs.
    Internal Wiring/Connections
    As far as the internal connections go (this is the internal wiring under the black cover, not the external wiring harness):
    Code:
    1 3 5 7
    2 4   8
    1-black (to actuator)
    2-white (to actuator)
    3-blue (to inner side of throttle open switch)
    4-red
    5-green
    6-n/c
    7-brown and also connected to outer blue wire
    8-yellow
  3. #23
    Munno Para West Adelaide
    Was this ever fixed? Im having the same problem!
  4. #24
    Apr 2008
    Illawarra, NSW
    Hey mate no unfortunately i needed the car back on the road and didnt have time to fiddle with it, so gave up on it and got a mate who was in the czech republic at the time to source me a new skoda one there which was quite a bit cheaper (but still not cheap)! I'm not sure if i still have my old one lying around, will have a look might be a good guinea pig for you if you're going to have a crack at repairing it....
  5. #25
    So the new throttle body fixed it though?
  6. #26
    Dec 2007
    Melburg East VIC
    Just read the entire thread, bit surprised no one suggested disconnecting the -ve terminal for 5 minutes again, connect back up, turn ignition on without turning the car, leave for about 2-3min from memory, the throttle body self aligns, you'll hear it ticking over, done this plenty of times on mine
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
  7. #27
    Ive read about that but never tried it. Alot of people saying they needed vagcom for it to allign it properly as it was the 'only' way. Will try it today and see though before buying a throttle body
  8. #28
    Apr 2008
    Illawarra, NSW
    I had vagcom at the time. Pretty certain I tried all that. Hopefully it will work for you, but for me it was definitely some sort of fault with the throttle body itself. The new one solved the issue immediately
  9. #29
    So ive tried a second hand throttle body and same codes came up and would not clear! Surely both arent faulty? same problems as before, erratic idle, stutters when trying to drive it. No clue whats going on now!
  10. #30
    Apr 2008
    Illawarra, NSW
    Have you got vagcom? For me the old throttle body wouldn't align using that, where the new one did no problems. Would be interested to know if the second hand one aligns or not....
    I can't remember too much about the whole thing sorry and don't have the car anymore, hopefully one of the other guys will be able to help more
