So what do people reckon a reasonable price is then?
Mine is on its way out, so I'll prob be up for one soonish and I was figuring on about a grand for a new one anyway, esp with currency drops in recent months.
'04 BMP MkIV R32 #144
search getnew
That's a bit of a broad statement geoff, what makes you think it's on the way out.
http://cgi.ebay.com.au/Audi-Vw-Throttle-Body-058-133-063F-GENUINE-NEW_W0QQitemZ380100529188QQcmdZViewItemQQptZUK_Car sParts_Vehicles_CarParts_SM?hash=item380100529188& _trksid=p3286.c0.m14&_trkparms=66%3A2|65%3A1|39%3A 1|240%3A1318
Might be a way to save some $$$s.
Cheers guys. Mine has been cleaned/serviced once already and the intermittent idle fault has started coming back occassionally. (You know the deal, idles up & down between 1200 and 1400rpm or so, air con seems to cut out, and cruise control disables itself lol)
Can they be serviced a few times or will it need to be replaced soon? The car went into 'safe mode' once too which I'm pretty sure was related, just lost acceleration power as though it wasn't boosting. Was fine again next time I drove and hasn't happened since.
Oh and the gearbox has decided to start banging intermittent when I select 1st if I'm not completely stationery....but that's another topic. No I haven't been thrashing it!!
search getnew
Yep, sounds like what mine's doing - it only runs 5psi boost in safe mode too which just isn't enough Also on hot days in syd traffic (coming back from the wrecker) it's clearly not an option to have no A/C below 2000rpm
If it's just a carbon build up causing it to play up, this can be cleaned as often as need be - pretty simple job and seems to commonly solve the problem. From what I've been able to work out though there are no servicable components inside them so if something fails internally you are up for a new one.
That said I've currently got mine open having a sniff around inside it for anything obviously wrong. If I can figure out how I'll post up some pics. It's quite elaborate in there, but definately not $1000+ elaborate!!
Previously owned 2001 Golf GTi. Sold to forum member
Mick, we are looking at 2.9K between pins 1 and 2.
what happened with this story?????
