Results 1 to 4 of 4
Thread: Need help urgently!
    Jun 2012
    Need help urgently!
    Hi guys I have this problem and I cant seem to solve it. My car is the V5 03 model and at the moment the engine is erratically vibrating and shaking. I have replaced the coils (all of them) and the spark plugs are quite new.
    But what I cant understand is that when ever the ECU is reset the car runs fine again as if nothing has ever happened.
    Then about 3 days later the problem comes again and stays there until the ECU is reset again. Now I know the problem
    is about to happen because when ever I start the car it cranks and then engine turns over and starts but its very weak, the rev
    will go up down up down as if its going to stall and then stations at about 1000rpm. I know if I cant solve this problem, I
    may have to go to a VW dealer with no choice. Couple of days ago Ive changed the air filter also but the problem is still a
    mystery. Does anyone know what the problem might be? could it be the spark leads? Because the car is erratic at stop
    one or two cylinder is definitely miss firing. I want to sell my car ASAP but until I fix it i cant sell.
    Anyone with ideas?
    cheers
    Aug 2007
    Quote Originally Posted by JSJW View Post
    Anyone with ideas?
    cheers
    To explain why it runs fine is because you are indeed resetting the ECU like you say, then it learns the values and sees what it obviously doesn't like and runs bad, its always going to do that till you find the fault, Have it checked mate, sometimes if its seen in the flesh itll make sense to someone who knows them. If not there is various checks that can be done.
    Good luck
    Jmac
    Alba European
    May 2013
    Orange NSW
    I would say ignition and fuel is OK if resetting the computer makes it run. I would suspect the EGO sensors as they feed info to the computer to set mixture of fuel. Can you connect up a computer to monitor them? another option is to use a meter to see if the output changes from 1.0V or if the wires to them are broken.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    Jun 2012
    I was just researching last night and I came across something interesting that might help solve the problem. It's the Oxygen sensors. What you guys think? Engine light coming on, rough idle, engine pinging etc...how many oxygen sensors are in boras? anyone know good places to get them?
    cheers
